Choose the cluster configuration
Continue in the same terminal with LP_WORKDIR still set. Run cd "$LP_WORKDIR" if you opened a new terminal.
You’ll create one small system node and one Arm sandbox node. The system pool will use an e2-standard-2 node. Your Python workloads will use the separate c4a-standard-2 pool which uses Google Axion processors.
Set the names and networking for a dedicated tutorial cluster:
cd "$LP_WORKDIR"
export LOCATION=us-central1-c
export REGION=us-central1
export CLUSTER_NAME=gke-agent-sandbox
export NODE_POOL_NAME=axion-sandbox-pool
export MACHINE_TYPE=c4a-standard-2
export NAMESPACE=axion-sandbox-prototype
export NETWORK=gke-sandbox-vpc
export SUBNETWORK=gke-sandbox-subnet
Create a dedicated VPC network and subnet for the cluster. VPC networks and subnets have no cost on their own:
gcloud compute networks create "$NETWORK" \
  --project="$PROJECT_ID" --subnet-mode=custom
gcloud compute networks subnets create "$SUBNETWORK" \
  --project="$PROJECT_ID" --network="$NETWORK" \
  --region="$REGION" --range=10.0.0.0/20
You’ll use these environment variables for subsequent commands, so keep this terminal open or re-export them if you start a new session. us-central1-c is the default zone. If you hit C4A capacity issues, us-east4-a is a good alternative. Update both LOCATION and REGION, then recreate the subnet in the new region.
If you saved env.sh earlier, append these variables to it:
cat >> "$LP_WORKDIR/env.sh" << EOF
export LOCATION="$LOCATION"
export REGION="$REGION"
export CLUSTER_NAME="$CLUSTER_NAME"
export NODE_POOL_NAME="$NODE_POOL_NAME"
export MACHINE_TYPE="$MACHINE_TYPE"
export NAMESPACE="$NAMESPACE"
export NETWORK="$NETWORK"
export SUBNETWORK="$SUBNETWORK"
EOF
Check access, quota, and versions
The following commands enable the Google Kubernetes Engine (GKE) and Compute APIs on your project, which are required before you can create a cluster.
The commands also perform the following tasks:
  • Confirm that billing is active.
  • Verify that the Axion machine type is available in your zone.
  • Save the quota and available GKE versions for your chosen region to output/server-config.json for troubleshooting.
Run the commands:
gcloud billing projects describe "$PROJECT_ID"
gcloud services enable container.googleapis.com compute.googleapis.com --project="$PROJECT_ID"
gcloud compute machine-types describe "$MACHINE_TYPE" --zone="$LOCATION" --project="$PROJECT_ID"
gcloud compute regions describe "$REGION" --project="$PROJECT_ID" \
  --format='table(quotas.metric,quotas.limit,quotas.usage)'
gcloud container get-server-config --location="$LOCATION" --project="$PROJECT_ID" \
  --format=json > output/server-config.json
cat output/server-config.json
The saved server config lists the available GKE versions for your location. Query the config to see which versions are available in the regular release channel:
jq -r '.channels[] | select(.channel=="REGULAR") | .validVersions[]' output/server-config.json
Agent Sandbox requires GKE 1.36.3-gke.1767000 or later with the v1beta1 API. Pick the latest available version in the regular channel that meets this requirement. The version used for testing was 1.36.4-gke.1391000, but your version might be newer.
Set your chosen version and channel:
export CLUSTER_VERSION=1.36.4-gke.1391000   # replace with your chosen version
export RELEASE_CHANNEL=regular
If you’re using env.sh, append these variables to the file:
export CLUSTER_VERSION="$CLUSTER_VERSION"
export RELEASE_CHANNEL="$RELEASE_CHANNEL"
EOF
Provision the cluster
Run each provisioning command separately and check its result before continuing.
First, create the system pool:
gcloud beta container clusters create "$CLUSTER_NAME" \
  --project="$PROJECT_ID" --location="$LOCATION" \
  --cluster-version="$CLUSTER_VERSION" --release-channel="$RELEASE_CHANNEL" \
  --network="$NETWORK" --subnetwork="$SUBNETWORK" \
  --num-nodes=1 --machine-type=e2-standard-2 \
  --image-type=COS_CONTAINERD --disk-size=30 --enable-ip-alias
Add the Axion pool with gVisor enabled. C4A uses Hyperdisk boot storage, so set its disk type explicitly:
gcloud container node-pools create "$NODE_POOL_NAME" \
  --project="$PROJECT_ID" --cluster="$CLUSTER_NAME" --location="$LOCATION" \
  --machine-type="$MACHINE_TYPE" --num-nodes=1 \
  --image-type=COS_CONTAINERD --disk-type=hyperdisk-balanced --disk-size=100 \
  --sandbox=type=gvisor
Enable the managed Agent Sandbox feature:
gcloud beta container clusters update "$CLUSTER_NAME" \
  --project="$PROJECT_ID" --location="$LOCATION" --enable-agent-sandbox
Confirm that the Axion node is running before continuing:
gcloud container node-pools describe "$NODE_POOL_NAME" \
  --format="table(name,status,config.machineType,config.sandboxConfig.type)"
The node pool status should be RUNNING, the machine type c4a-standard-2, and the sandbox type gvisor.
Handle capacity failures
If the node pool can’t allocate a node, check the operation status:
gcloud container operations list --project="$PROJECT_ID" --location="$LOCATION" \
  --filter="operationType=CREATE_NODE_POOL" --format="table(name,status,statusMessage)"
An insufficient-capacity error means that no c4a-standard-2 nodes were available in LOCATION. Delete the cluster, then retry in a different zone or with a larger machine type:
gcloud container clusters delete "$CLUSTER_NAME" \
  --project="$PROJECT_ID" --location="$LOCATION" --quiet
To try a different zone, update LOCATION and re-run the commands under Provision the cluster :
export LOCATION=us-central1-a
To try a larger machine type, update MACHINE_TYPE and re-run the commands under Provision the cluster :
export MACHINE_TYPE=c4a-standard-4
For a quota error, the statusMessage names the quota that was exceeded. Go to IAM & Admin > Quotas in the Google Cloud console, find that quota, and request an increase before retrying.
Install the matching kubectl version
Now that the cluster exists, install a kubectl version within one minor version of its control plane, following the Kubernetes version skew policy . Set KUBECTL_VERSION to match the minor of the CLUSTER_VERSION that you chose earlier.
The following block detects your OS and architecture, downloads the matching binary, and verifies its checksum. Run it as a subshell so that a download failure stops the block:
  set -eu
  KUBECTL_VERSION=v1.36.3
  case "$(uname -s)" in
    Linux) KUBECTL_OS=linux ;;
    Darwin) KUBECTL_OS=darwin ;;
    *) echo 'Use a native kubectl build for your OS.' >&2; exit 1 ;;
  esac
  case "$(uname -m)" in
    aarch64|arm64) KUBECTL_ARCH=arm64 ;;
    x86_64|amd64) KUBECTL_ARCH=amd64 ;;
    *) echo 'Use a native kubectl build for your architecture.' >&2; exit 1 ;;
  esac
  DOWNLOAD_DIR=$(mktemp -d)
  cd "$DOWNLOAD_DIR"
  KUBECTL_URL="https://dl.k8s.io/release/$KUBECTL_VERSION/bin/$KUBECTL_OS/$KUBECTL_ARCH/kubectl"
  curl -fL "$KUBECTL_URL" -o kubectl
  curl -fL "$KUBECTL_URL.sha256" -o kubectl.sha256
  if [ "$KUBECTL_OS" = linux ]; then
    printf '%s  kubectl\n' "$(cat kubectl.sha256)" | sha256sum --check
  else
    printf '%s  kubectl\n' "$(cat kubectl.sha256)" | shasum -a 256 --check
  fi
  mkdir -p "$HOME/.local/bin"
  chmod 755 kubectl
  cp kubectl "$HOME/.local/bin/kubectl"
export PATH="$HOME/.local/bin:$PATH"
hash -r
kubectl version --client
Add the PATH entry to your shell startup file if desired.
Verify the Arm sandbox pool
Obtain cluster credentials and save the explicit context for later helper commands:
gcloud container clusters get-credentials "$CLUSTER_NAME" \
export GKE_CONTEXT="$(kubectl config current-context)"
If you’re using env.sh, append GKE_CONTEXT:
echo "export GKE_CONTEXT=\"$GKE_CONTEXT\"" >> "$LP_WORKDIR/env.sh"
Check that the nodes are ready and note the architecture, machine type, and sandbox runtime:
kubectl --context "$GKE_CONTEXT" get nodes \
  -L kubernetes.io/arch,node.kubernetes.io/instance-type,sandbox.gke.io/runtime
The sandbox node row should show arm64, c4a-standard-2, and gvisor:
        NAME                                               STATUS   ROLES    AGE   VERSION   ARCH    INSTANCE-TYPE    RUNTIME
gke-gke-agent-sandbox-axion-sandbox-pool-<hash>   Ready    <none>   2m    v1.36.x   arm64   c4a-standard-2   gvisor
gke-gke-agent-sandbox-default-pool-<hash>         Ready    <none>   4m    v1.36.x   amd64   e2-standard-2
Confirm that the gVisor runtime class is registered:
kubectl --context "$GKE_CONTEXT" get runtimeclass gvisor
The output is similar to:
        NAME     HANDLER   AGE
gvisor   runsc     2m
Confirm that the Agent Sandbox API resources are available:
kubectl --context "$GKE_CONTEXT" api-resources --api-group=extensions.agents.x-k8s.io
        NAME                 SHORTNAMES   APIVERSION                                    NAMESPACED   KIND
sandboxclaims                     extensions.agents.x-k8s.io/v1beta1            true         SandboxClaim
sandboxtemplates                  extensions.agents.x-k8s.io/v1beta1            true         SandboxTemplate
sandboxwarmpools                  extensions.agents.x-k8s.io/v1beta1            true         SandboxWarmPool
Save the cluster and node pool configuration to the output/ directory:
gcloud beta container clusters describe "$CLUSTER_NAME" \
  --project="$PROJECT_ID" --location="$LOCATION" --format=json > output/cluster.json
  --format=json > output/node-pool.json
You’ve enabled Agent Sandbox and prepared a gVisor node pool on Google Axion.
Next, you’ll define the Python environment, claim a sandbox, and verify its filesystem restrictions.
