Run agent-generated code in an isolated remote sandbox
Coding agents can write useful programs. However, running agent-generated code on your local machine gives untrusted code direct access to your files, credentials, and network. Agent Sandbox on Google Kubernetes Engine (GKE) runs untrusted, model-generated code in a secure, isolated environment away from your local machine.
Each sandbox Pod runs under gVisor, which places a user-space application kernel between the workload and the host kernel. Agent Sandbox applies a default-deny network posture to sandboxed workloads.
To use agent sandboxes, create a Google Kubernetes Engine (GKE) Standard cluster and enable Agent Sandbox on a Google Axion node pool.
In this Learning Path, you’ll create a cluster with a pool of pre-warmed sandboxes. When you need to run code, you’ll allocate a sandbox from the pool and submit your code to it from your local machine.
Your agent and your terminal will stay on your local machine, and you’ll run the generated code remotely.
Set up your local machine
Your local machine will manage the Kubernetes resources. The Python workloads will run on the remote Arm node. You don’t need local Docker, KVM, or a local gVisor installation.
Use Ubuntu Linux or macOS. The Learning Path was tested on an Arm Linux system and on macOS.
Install the required tools
Install the Google Cloud CLI (with gke-gcloud-auth-plugin) and Python 3.
The Google Cloud CLI provisions and manages the GKE cluster and authenticates kubectl. Python 3 runs the helper scripts that you’ll use later.
Ubuntu Linux
On Ubuntu Linux, add the Google Cloud APT repository and install the packages:
sudo apt-get update
curl -fsSL https://packages.cloud.google.com/apt/doc/apt-key.gpg -o /tmp/gke-cloud-apt-key.gpg
sudo gpg --dearmor --yes --output /usr/share/keyrings/cloud.google.gpg /tmp/gke-cloud-apt-key.gpg
printf '%s\n' 'deb [signed-by=/usr/share/keyrings/cloud.google.gpg] https://packages.cloud.google.com/apt cloud-sdk main' \
  | sudo tee /etc/apt/sources.list.d/google-cloud-sdk.list
sudo apt-get update
sudo apt-get install -y google-cloud-cli google-cloud-cli-gke-gcloud-auth-plugin python3 python3-venv jq
macOS
On macOS, install Homebrew if needed, then install the Cloud CLI, its authentication plugin, and Python:
eval "$(/opt/homebrew/bin/brew shellenv)"
brew update
brew install --cask gcloud-cli
brew install python jq
export PATH="$(brew --prefix)/share/google-cloud-sdk/bin:$PATH"
gcloud components install beta gke-gcloud-auth-plugin
Authenticate and confirm the tools are ready
Find your project ID on the front page of the Google Cloud console. Set the PROJECT_ID environment variable and sign in:
export PROJECT_ID="REPLACE_WITH_YOUR_PROJECT_ID"
gcloud auth login
gcloud config set project "$PROJECT_ID"
gcloud projects describe "$PROJECT_ID" --format='value(projectId)'
command -v gcloud gke-gcloud-auth-plugin python3
gcloud beta container clusters update --help 2>/dev/null | grep -q enable-agent-sandbox \
  && echo "enable-agent-sandbox flag: present" \
  || echo "enable-agent-sandbox flag: NOT FOUND — upgrade the Cloud CLI"
The final command in the set checks that your Cloud CLI version supports Agent Sandbox. If it reports NOT FOUND, upgrade the CLI before continuing.
If you don’t have a browser available, use gcloud auth login --no-launch-browser and follow the instructions.
Create a working directory
Create a working directory and set LP_WORKDIR. You can use LP_WORKDIR to return to this directory:
mkdir -p ~/gke-agent-sandbox
cd ~/gke-agent-sandbox
export LP_WORKDIR="$PWD"
mkdir -p output runs
output/ stores command output that you can save for reference, such as cluster configuration, pod specs, and workload results. runs/ holds per-task subdirectories created by the helper scripts, one for each sandbox claim lifecycle.
If you want to be able to restore your session in a new terminal, save LP_WORKDIR and PROJECT_ID to a file called env.sh:
cat > "$LP_WORKDIR/env.sh" << EOF
export LP_WORKDIR="$LP_WORKDIR"
export PROJECT_ID="$PROJECT_ID"
EOF
You can skip this step and manage the variables yourself if you prefer to use the same terminal throughout.
If you save the variables to env.sh, source them at the start of any new terminal with source ~/gke-agent-sandbox/env.sh.
You’ve installed the Google Cloud CLI and Python, created the working directory, and confirmed the Cloud CLI supports Agent Sandbox.
Next, you’ll create the dedicated GKE cluster and its Arm sandbox node pool, then install the matching kubectl.
