So far, you have run three individual workflows covering the tasks in the ML lifecycle:
With GitHub Actions, you can build an end-to-end custom MLOPs workflow that combines and automates the individual workflows.
To demonstrate this, the repository contains a workflow in .github/workflows/train-test-deploy-model.yml that automates the individual steps.
Here is the complete Train, Test, and Deploy Model workflow file:
name: Train, Test and Deploy Model
on:
workflow_dispatch:
push:
branches: main
jobs:
train-model:
name: Train the Model
runs-on: ubuntu-22.04-arm-os # Custom ARM64 runner
container:
image: armswdev/pytorch-arm-neoverse:r24.07-torch-2.3.0-openblas
options: --user root
steps:
- name: Checkout code
uses: actions/checkout@v4
- name: Run training script
run: python scripts/train_model.py
- name: Upload Artifact
uses: actions/upload-artifact@v4
with:
path: ${{ github.workspace }}/models/traffic_sign_net.pth
retention-days: 5
test-model-openblas:
name: Test with OpenBLAS
needs: train-model
container:
steps:
- name: Download model artifact
uses: actions/download-artifact@v4
with:
- name: Test with OpenBLAS
run: python scripts/test_model.py --model models/traffic_sign_net.pth | tee openblas.txt
with:
path: openblas.txt
retention-days: 5
test-model-onednn-acl:
name: Test with Arm Compute Library
needs: train-model
container:
image: armswdev/pytorch-arm-neoverse:r24.07-torch-2.3.0-onednn-acl
steps:
with:
- name: Test with oneDNN and Arm Compute Library
run: python scripts/test_model.py --model models/traffic_sign_net.pth | tee acl.txt
with:
path: acl.txt
retention-days: 5
compare-results:
name: Compare Profiler Reports
needs: [test-model-openblas, test-model-onednn-acl]
steps:
- name: Download OpenBLAS artifact
with:
- name: Download ACL artifact
with:
- name: Parse output
run: python scripts/parse_output.py openblas.txt acl.txt
- name: Remove output files
run: rm -rf openblas.txt acl.txt
push-artifact:
name: Push the updated model
needs: compare-results
steps:
with:
path: models/
- name: Push updated model to repository
run: |
git config --global user.name "GitHub Actions"
git config --global user.email "actions@users.noreply.github.com"
git add models/traffic_sign_net.pth
git commit -m "Add updated model"
git push
deploy-to-dockerhub:
name: Build and Push Docker Image to DockerHub
needs: push-artifact
steps:
uses: actions/checkout@v3
- name: Set up Docker Buildx
uses: docker/setup-buildx-action@v3
- name: Log in to DockerHub
uses: docker/login-action@v3
with:
username: ${{ secrets.DOCKER_USERNAME }}
password: ${{ secrets.DOCKER_PASSWORD }}
- name: Build and Push Docker Image
run: |
docker buildx build --platform linux/arm64 -t ${{ secrets.DOCKER_USERNAME }}/gtsrb-image:latest --push .
These steps should look familiar and now they are put together to curate an end-to-end MLOPs workflow.
The training and testing steps are run like before. The output report is saved and parsed to show the compare the performance changes in inference time.
The trained model is updated in the repository.
The deployment step connects to DockerHub, pushes the containerized model and scripts, which can then be downloaded and run.
The steps depend on each other, requiring the previous one to run before the next is triggered. The entire workflow is triggered automatically any time a change is pushed into the main branch of your repository.
Using what you have learned, navigate to the Train, Test and Deploy workflow and run it.
The diagram below shows the end-to-end workflow, the relationship between the steps, and the time required to run each step:
You have run an MLOps workflow using GitHub Actions with Arm-hosted runners for managing all of the steps in your ML application’s lifecycle.
