Continuously monitoring the performance of your machine learning models in production is crucial to maintaining effectiveness over time. The performance of your ML model can change due to various factors ranging from data-related issues to environmental factors.
In this section, you will change the PyTorch backend being used to test the trained model. You will learn how to measure and continuously monitor the inference performance using your workflow.
In the previous section, you used the PyTorch 2.3.0 Docker Image compiled with OpenBLAS from DockerHub to run your testing workflow. PyTorch can be run with other backends. You will now modify the testing workflow to use PyTorch 2.3.0 Docker Image compiled with OneDNN and the Arm Compute Library.
The Arm Compute Library is a collection of low-level machine learning functions optimized for Arm’s Cortex-A and Neoverse processors and Mali GPUs. Arm-hosted GitHub runners use Arm Neoverse CPUs, which make it possible to optimize your neural networks to take advantage of processor features. ACL implements kernels, which are also known as operators or layers, using specific instructions that run faster on AArch64.
ACL is integrated into PyTorch through oneDNN , an open-source deep neural network library.
Two different PyTorch docker images for Arm Neoverse CPUs are available on DockerHub .
Up until this point, you used the r24.07-torch-2.3.0-openblas container image to run workflows. The oneDNN container image is also available to use in workflows. These images represent two different PyTorch backends which handle the PyTorch model execution.
In your browser, open and edit the file .github/workflows/test_model.yml.
Update the container.image parameter to armswdev/pytorch-arm-neoverse:r24.07-torch-2.3.0-onednn-acl and save the file by committing the change to the main branch:
jobs:
test-model:
name: Test the Model
runs-on: ubuntu-22.04-arm-os # Custom ARM64 runner
container:
image: armswdev/pytorch-arm-neoverse:r24.07-torch-2.3.0-onednn-acl
options: --user root
# Steps omitted
Trigger the Test Model job again by clicking the Run workflow button on the Actions tab.
The test workflow starts running.
Navigate to the workflow run on the Actions tab, click into the job, and expand the Run testing script step.
You see a change in the performance results with OneDNN and ACL kernels being used.
The output is similar to:
Accuracy of the model on the test images: 90.48%
Name Self CPU % Self CPU CPU total % CPU total CPU time avg # of Calls
model_inference 4.63% 304.000us 100.00% 6.565ms 6.565ms 1
aten::conv2d 0.18% 12.000us 56.92% 3.737ms 1.869ms 2
aten::convolution 0.30% 20.000us 56.74% 3.725ms 1.863ms 2
aten::_convolution 0.43% 28.000us 56.44% 3.705ms 1.853ms 2
aten::mkldnn_convolution 47.02% 3.087ms 55.48% 3.642ms 1.821ms 2
aten::max_pool2d 0.15% 10.000us 25.51% 1.675ms 837.500us 2
aten::max_pool2d_with_indices 25.36% 1.665ms 25.36% 1.665ms 832.500us 2
aten::linear 0.18% 12.000us 9.26% 608.000us 304.000us 2
aten::clone 0.26% 17.000us 9.08% 596.000us 149.000us 4
aten::addmm 8.50% 558.000us 8.71% 572.000us 286.000us 2
Self CPU time total: 6.565ms
For the ACL results, notice that the Self CPU time total is lower compared to the OpenBLAS run in the previous section.
The names of the layers have also changed, where the aten::mkldnn_convolution is the kernel optimized to run on the Arm architecture. That operator is the main reason the inference time is improved, made possible by using ACL kernels.
In the next section, you will learn how to automate the deployment of your model.
