Fork the example into a GitHub Organization or Team that has access to Arm-hosted GitHub runners. If a repository with the same name already exists, change the repository name when you fork.
Check the Actions tab for a successful run of
.github/workflows/train-model.yml and verify that a model artifact was created. The workflow trains inside a PyTorch 2.3.0 Docker image compiled with OpenBLAS and saves the trained model for later steps.Update the testing workflow to use the backend with oneDNN and ACL instead of the OpenBLAS-based image, then trigger the run.
Review the workflow run logs and any artifacts produced by the testing workflow. The artifacts and logs report the model’s inference time. Compare outputs from the OpenBLAS and oneDNN+ACL runs to see differences.
Add
DOCKER_USERNAME with your Docker Hub username and DOCKER_PASSWORD with your Docker Hub Personal Access Token as repository secrets under Settings > Secrets and variables > Actions.
