You can create a simple extension in Python to get started learning how Copilot connects to extensions.
Use a text editor to save the Python code below to a file named simple-extension.py on Linux computer with Python installed.
import os
from flask import Flask, request, jsonify
import requests
app = Flask(__name__)
@app.route("/", methods=["GET"])
def home():
return "Hello! Welcome to the example GitHub Copilot Extension in Python!"
@app.route("/", methods=["POST"])
def handle_post():
# Identify the user, using the GitHub API token provided in the request headers.
token_for_user = request.headers.get("X-GitHub-Token")
user_response = requests.get("https://api.github.com/user", headers={"Authorization": f"token {token_for_user}"})
user = user_response.json()
print("User:", user['login'])
# Parse the request payload and log it.
payload = request.json
print("Payload:", payload)
# Insert a special pirate-y system message in our message list.
messages = payload['messages']
messages.insert(0, {
"role": "system",
"content": "You are a helpful assistant that replies to user messages with a focus on software development. Don't answer questions that are not related to software or computing."
"role": "system",
"content": f"Start every response with the user's name, which is @{user['login']}"
# Use Copilot's LLM to generate a response to the user's messages, with
# our extra system messages attached.
copilot_response = requests.post(
"https://api.githubcopilot.com/chat/completions",
headers={
"Authorization": f"Bearer {token_for_user}",
"Content-Type": "application/json"
json={
"messages": messages,
"stream": True
stream=True
# Stream the response straight back to the user.
return app.response_class(copilot_response.iter_content(), mimetype='application/json')
port = int(os.environ.get("PORT", 3000))
if __name__ == "__main__":
app.run(port=port)
You might need to install the following Python packages:
sudo apt update
sudo apt install python3-pip python-is-python3 python3-venv -y
Create a Python virtual environment to run the extension:
python -m venv venv
source venv/bin/activate
Your shell prompt now includes (venv) indicating that the virtual environment is active.
Install the required Python packages:
pip install flask requests
Run the extension using Python:
python ./simple-extension.py
The output is similar to the text below:
* Serving Flask app 'simple-extension'
* Debug mode: off
WARNING: This is a development server. Do not use it in a production deployment. Use a production WSGI server instead.
* Running on http://127.0.0.1:3000
Press CTRL+C to quit
Your extension is running, but it needs to be connected to Copilot.
Continue to learn how to share your extension with Copilot.
