Create a Google Cloud C4A Arm-based virtual machine
Provision a C4A Arm-based virtual machine (VM) on Google Cloud Platform (GCP) using the c4a-standard-4 machine type (4 vCPUs, 16 GB memory) in the Google Cloud console.
Note
For support on GCP setup, see the Learning Path Getting started with Google Cloud Platform .
Use the Google Cloud console to create a C4A Arm virtual machine
To create a VM based on the C4A instance type:
  1. Navigate to the Google Cloud console .
  2. Go to Compute Engine > VM Instances and select Create Instance.
  3. Under Machine configuration:
    • Populate fields such as Instance name, Region, and Zone.
    • Set Series to C4A.
    • Select c4a-standard-4 for machine type.
Image Alt Text:Google Cloud console interface showing the Create Instance page with Machine configuration section. Series is set to C4A and machine type shows c4a-standard-4 selected. The dialog displays configuration options for CPU, memory, and other VM settings.Creating a C4A Arm-based virtual machine in Google Cloud console
  1. Under OS and Storage, select Change. Choose an Arm64-based OS image. For this Learning Path, select Ubuntu 24.04 LTS.
  2. Change the size of the primary disk from 10 GB to 100 GB
  3. Choose Select to confirm your OS choice.
  4. Under Networking, enable Allow HTTP traffic and Allow HTTPS traffic.
  5. In the Network tags field, add allow-tcp-8080 to allow Gerrit dashboard traffic.
Image Alt Text:Google Cloud console interface showing the Networking tab for VM instance configuration. The Network tags field displays allow-tcp-8080 to enable firewall rule for Gerrit dashboard traffic on port 8080. Other networking options and VM configuration controls are visible.Adding the TCP/8080 firewall rule to our VM
  1. Select Create to launch your VM instance.
After the VM is ready, you’ll see an SSH button next to your instance in the VM list. The public IP address for your VM also appears here. Copy the public IP address — you’ll need it later to connect to Gerrit.
Select SSH to open a shell session directly in your browser.
Image Alt Text:Google Cloud console showing the VM Instances list with a running VM instance. The SSH button is highlighted next to the instance entry, with the public IP address visible in the same row. This shows how to access the SSH terminal to connect to your Arm-based VM.Invoke a SSH session into your running VM instance
A window from your browser will come up and you’ll now see a shell into your VM instance:
Image Alt Text:Browser-based terminal window showing an active shell session on the Ubuntu VM instance. The command prompt is ready for input. This demonstrates successful connection to your C4A Arm virtual machine on Google Cloud.Terminal shell in your VM instance
You’ve now created an Arm-based Google Axion C4A VM instance that you’ll use to deploy Gerrit. You’ve also opened a shell session into the instance.
Next, you’ll install Gerrit on the VM instance.
