Explore related resources
Give feedback
AI-assisted
Close
Which Google Cloud port must be open to access the Gerrit web console?
Open TCP port 8080. Create a firewall rule in the Google Cloud console to allow incoming traffic on port 8080 so the Gerrit web interface is reachable.
What virtual machine configuration should I use for this deployment?
Use a Google Axion C4A instance with the c4a-standard-4 machine type (4 vCPUs, 16 GB memory). The VM runs Ubuntu 24.04 LTS on arm64.
What packages should I install before setting up Gerrit?
Update the system and install wget, default-jdk, git, and net-tools. The steps show running apt update and apt upgrade before installing these tools.
How do I verify that Gerrit is running after installation?
Confirm that the Gerrit web console loads on port 8080 after completing the install steps. If it doesn’t load, review the command outputs from the installation for errors.
How do I run the benchmark and what should I expect?
Clone the gerrit_test repository into your VM and run the provided script with SYNTH_PROFILE=production_like and REQUIRE_GERRIT_METRICS=true. The script exercises Gerrit functions and captures timing and performance data for baseline measurement.
