Optimize performance using Link-Time Optimization with GCC
Deploy LTO
A simple use case
Enable link-time optimization with GCC by passing the -flto flag during both compilation and linking.
For a traditional, stepwise build of an executable, compile each translation unit with LTO enabled:
gcc -c -O2 -flto component-1.c
gcc -c -O2 -flto component-2.c
gcc -o myprog -flto -O2 component-1.o component-2.o
Each object file contains LTO information embedded in special sections. The final link step performs whole-program optimization before generating machine code.
For small programs, you can simplify this into a single command:
gcc -o myprog -flto -O2 component-1.c component-2.c
Both approaches produce an executable that benefits from link-time optimization across all translation units. The -O2 optimization level is recommended as a baseline, though you can also use -O3 for more aggressive optimizations.
Modify LTO behavior
Flexible object files
When compiling with -flto, GCC normally emits slim LTO objects. These object files contain only GCC’s internal intermediate representation (GIMPLE bytecode) and no conventional machine code. As a result, they can only be linked by an LTO-capable linker invocation.
For libraries intended for broader reuse—or when you need compatibility with non-LTO builds—you can retain conventional object code alongside the LTO data using the -ffat-lto-objects flag:
gcc -c -O2 -flto -ffat-lto-objects component-1.c
With this option enabled, GCC emits both:
  • The intermediate representation used for LTO
  • The non-LTO object code that would normally be produced
Fat LTO objects provide greater compatibility at the cost of increased object file size (typically 1.5-2x larger). Use this option when building static or shared libraries that might be linked without LTO.
Parallelization
Link-time optimization can be computationally expensive, especially for larger programs. GCC supports parallelizing LTO to reduce build times by distributing the optimization work across multiple CPU cores.
Control this behavior through the -flto flag:
  • -flto=auto enables automatic parallelization based on available system resources
  • -flto=<n> explicitly specifies the number of parallel LTO jobs to run
For example:
gcc -O2 -flto=4 -o myprog component-1.c component-2.c
When parallelization is enabled, GCC partitions the program into multiple units of roughly equal size. The compiler attempts to minimize cross-partition references, which could otherwise reduce the effectiveness of certain whole-program optimizations. For best results, set the parallelization level to match the number of available CPU cores.
Caching
During iterative development, repeatedly recompiling with LTO can increase build times. GCC provides support for caching intermediate LTO results to speed up incremental builds by reusing previously computed optimization information.
Enable this using the -flto-incremental=<path> option:
gcc -O2 -flto -flto-incremental=lto-cache -c component-1.c
When enabled, GCC stores intermediate optimization results in the specified directory. Subsequent builds reuse previous work where possible, significantly reducing edit–compile cycle times. The cache directory grows over time, so you may need to clean it periodically during development.
You’ve learned how to enable LTO with the -flto flag for both simple and complex build scenarios. You can now configure LTO behavior using fat objects for compatibility, parallelize LTO jobs to speed up builds, and cache intermediate results during development.
Next, you’ll see concrete performance and code size results from enabling LTO on industry-standard benchmarks.
