What you've learned
You should now know how to:
  • Create Azure Container Instances.
  • Run a Docker container in Azure Container Instances.
  • Enable Admin in Azure Container Registry, which is required when you are deploying Docker containers from the Azure Container Registry.
Knowledge Check
1. Which tab do you use to configure port mapping in the Azure Container Instance?
2. What do you need to deploy a container from the Azure Container Registry to the Azure Container instance?
