In this section, you will learn how to create a Docker image for the People.WebApp. Then, you will learn how to push this image to the Azure Container Registry. This image can then be deployed to various cloud services. To complete this part we will use the Windows on Arm device. Alternatively, you can use the VM you created in the previous steps.
Start by opening a new Command Prompt window, and then type:
wsl
In the wsl terminal type:
git clone https://github.com/dawidborycki/People.WebApp.git
This will clone the source code to the local folder (C:\Users\d\People.WebApp):
Cloning into 'People.WebApp'...
remote: Enumerating objects: 148, done.
remote: Counting objects: 100% (148/148), done.
remote: Compressing objects: 100% (88/88), done.
remote: Total 148 (delta 57), reused 138 (delta 51), pack-reused 0
Receiving objects: 100% (148/148), 977.91 KiB | 667.00 KiB/s, done.
Resolving deltas: 100% (57/57), done.
You will now create the Dockerfile using Visual Studio Code. To do so, proceed as follows:
Figure 18. Adding a Dockerfile
This will activate the Add Docker Files wizard, in which you select the following:
After a short while, the application folder will be supplemented by two additional files: .dockerignore and Dockerfile. The first one is like. gitignore and includes file and folder files, which will be excluded from the image build. The second one is more important and specifies the exact operations to containerize an application. In other words, it instructs Docker on how to build the Docker image.
The actual Dockerfile depends on the programming tools you used to create your application. In this specific case, the Dockerfile looks as follows:
FROM mcr.microsoft.com/dotnet/aspnet:7.0 AS base
WORKDIR /app
EXPOSE 5000
ENV ASPNETCORE_URLS=http://+:5000
# Creates a non-root user with an explicit UID and adds permission to access the /app folder
# For more info, please refer to https://aka.ms/vscode-docker-dotnet-configure-containers
RUN adduser -u 5678 --disabled-password --gecos "" appuser && chown -R appuser /app
USER appuser
FROM --platform=$BUILDPLATFORM mcr.microsoft.com/dotnet/sdk:7.0 AS build
ARG configuration=Release
WORKDIR /src
COPY ["People.WebApp.csproj", "./"]
RUN dotnet restore "People.WebApp.csproj"
COPY . .
WORKDIR "/src/."
RUN dotnet build "People.WebApp.csproj" -c $configuration -o /app/build
FROM build AS publish
RUN dotnet publish "People.WebApp.csproj" -c $configuration -o /app/publish /p:UseAppHost=false
FROM base AS final
WORKDIR /app
COPY --from=publish /app/publish .
ENTRYPOINT ["dotnet", "People.WebApp.dll"]
The Dockerfiles start with the FROM instruction, which indicates the base image. Usually, base images contain a slim operating system with code build tools. The above Dockerfile uses a multi-stage build, in which two different base images are used. Both base images come from the dotnet repository under the Microsoft container registry (mcr.microsoft.com/dotnet) and are tagged aspnet:7.0 or sdk:7.0. The first image contains only the .NET runtime, which is required to run the application from binaries. The second image includes the SDK needed to build the application. The runtime-only base image is used in the final Docker image to reduce its size.
The Dockerfile includes several other instructions:
ARG to specify the Dockerfile variablesWORKDIR to change the directory inside the building imageCOPY to copy files between the build context (typically a working directory, where you invoke the docker build command) and the building imageRUN to execute commands inside the building imageENTRYPOINT to indicate the container entry point, which is the command to perform when the container is created and runIn the above example, the Dockerfile will use dotnet build and dotnet publish commands from the .NET SDK to build an application from the source code and prepare the binaries. Note that the last command, dotnet People.WebApp.dll, is equivalent to dotnet run, which we used in the first section of this learning path.
