Prepare the development environment
In this section, you prepare a SUSE Linux Enterprise Server (SLES) arm64 virtual machine and install the core components required to build machine learning workflow pipelines using Flyte.
Flyte provides workflow orchestration for scalable ML pipelines, while gRPC enables efficient communication between distributed services used within those pipelines.
Running these tools natively on Arm-based Axion processors ensures efficient execution of ML workflows.
Architecture overview
The development environment consists of a single-node setup used to build and run distributed machine learning workflows.
SUSE Linux Enterprise Server (arm64)
Python 3.11 Environment
Flyte SDK
gRPC Communication Libraries
Update the system
Update the system packages.
sudo zypper refresh
sudo zypper update -y
Install system dependencies
Install Python, development tools, and system libraries required to run Flyte workflows.
sudo zypper install -y \
python311 python311-devel python311-pip \
gcc gcc-c++ make \
git curl
Verify Python installation:
python3.11 --version
The output is similar to:
        Python 3.11.10
Why this matters:
  • Python 3.11 provides improved performance and memory efficiency
  • Modern workflow libraries are optimized for Python 3.11
  • Ensures compatibility with Flyte and gRPC libraries
Create a virtual environment
flytekit 1.16.15 requires setuptools<70, while grpcio-tools requires setuptools>=77. These constraints are mutually exclusive at the system level. A virtual environment resolves this by isolating the dependency graph from any pre-installed system packages, allowing pip to resolve all constraints together from scratch.
Create and activate a virtual environment:
python3.11 -m venv flyte-env
source flyte-env/bin/activate
Your prompt will change to show (flyte-env), confirming the environment is active. All subsequent pip install commands in this Learning Path use this environment.
Install Flyte SDK and gRPC libraries
With the virtual environment active, upgrade pip and install Flyte together with the gRPC communication libraries in a single step. This lets pip resolve a consistent set of versions, including setuptools, across all packages at once.
pip install --upgrade pip
pip install flytekit grpcio grpcio-tools protobuf
Verify Flyte installation:
python -c "import flytekit; print(flytekit.__version__)"
        1.16.15
Verify gRPC installation:
python -c "import grpc; import grpc_tools; import google.protobuf; print('gRPC libraries OK')"
        gRPC libraries OK
This confirms that Flyte and the gRPC libraries are correctly installed and compatible within the virtual environment.
Install Flyte CLI
The Flyte CLI is a standalone binary and doesn’t use pip, so you install it to the system path independently of the virtual environment.
curl -L https://github.com/flyteorg/flytectl/releases/latest/download/flytectl_Linux_arm64.tar.gz -o flytectl.tar.gz
tar -xzf flytectl.tar.gz
sudo mv flytectl /usr/local/bin/
Verify Flyte CLI installation
flytectl version
  "App": "flytectl",
  "Build": "0a0cbce",
  "Version": "0.8.18",
  "BuildTime": "2026-03-16 11:18:15.958506423 +0000 UTC m=+0.010167662"
This confirms that the Flyte CLI is correctly installed.
In this section, you learned how to:
  • Prepare a SUSE arm64 environment for ML workflow development
  • Install Python 3.11 and development dependencies
  • Create a virtual environment to resolve the setuptools conflict between flytekit and grpcio-tools
  • Install Flyte SDK and gRPC libraries in a single isolated environment
  • Install Flyte CLI tools
In the next section, you will create a gRPC-based feature engineering service that will be integrated with the Flyte ML workflow pipeline.
