Understand Flyte and gRPC ML workflows on Google Axion
Create a Google Axion C4A Arm virtual machine
Install Flyte and gRPC tools on Axion
Build a gRPC feature engineering service
Create ML Training Workflow
Execute and validate the ML pipeline
Understand the distributed ML architecture
In this section, you create a machine learning workflow pipeline using Flyte. Flyte workflows allow developers to define machine learning pipelines as Python tasks with explicit dependencies. This enables reproducible and scalable pipeline execution.
The workflow you build will perform the following steps:
This demonstrates how Flyte orchestrates tasks across distributed services within a machine learning pipeline.
The Flyte workflow interacts with the gRPC feature engineering service created in the previous section.
Flyte Workflow
v
Dataset Loader Task
v
Data Preprocessing Task
v
Feature Engineering (gRPC Service)
v
Model Training Task
v
Model Evaluation Task
v
Pipeline Result
This architecture separates workflow orchestration from feature generation, allowing different components of the pipeline to scale independently.
Create the workflow file.
cd $HOME/flyte-ml-pipeline
vi workflow.py
Add the following code.
from flytekit import task, workflow
import grpc
import feature_pb2
import feature_pb2_grpc
@task
def load_dataset() -> int:
print("Loading dataset")
return 10
@task
def preprocess_data(size: int) -> int:
print("Preprocessing dataset:", size)
return size * 2
@task
def generate_features(data: int) -> int:
channel = grpc.insecure_channel("localhost:50051")
stub = feature_pb2_grpc.FeatureServiceStub(channel)
response = stub.GenerateFeatures(
feature_pb2.FeatureRequest(value=data)
return response.feature
@task
def train_model(feature: int) -> float:
print("Training model with feature:", feature)
accuracy = feature / 20.0
return accuracy
@task
def evaluate_model(acc: float) -> str:
print("Model accuracy:", acc)
if acc > 0.5:
return "Model performance good"
else:
return "Model performance needs improvement"
@workflow
def ml_pipeline() -> str:
data = load_dataset()
processed = preprocess_data(size=data)
feature = generate_features(data=processed)
accuracy = train_model(feature=feature)
result = evaluate_model(acc=accuracy)
return result
if __name__ == "__main__":
result = ml_pipeline()
print("Pipeline result:", result)
The workflow consists of several tasks:
Load Dataset
Preprocess Data
Model Training
Model Evaluation
Pipeline Result
In this section, you learned how to:
In the next section, you will run the complete ML training pipeline and observe how Flyte interacts with the feature engineering service during workflow execution.
