This section shows you how to install Apache Flink and its required dependencies on a Google Cloud Platform (GCP) SUSE Arm64 virtual machine.
sudo zypper refresh
sudo zypper update -y
sudo zypper install -y java-17-openjdk java-17-openjdk-devel
This step ensures you have the latest system updates and the Java runtime needed to execute Flink applications.
Navigate to /opt (a standard location for system-wide tools) and download the official Flink distribution:
cd /opt
sudo wget https://dlcdn.apache.org/flink/flink-2.1.1/flink-2.1.1-bin-scala_2.12.tgz
This command retrieves the official Flink binary distribution for installation on your VM.
Flink 2.0.0 introduced Disaggregated State Management architecture, which enables more efficient resource utilization in cloud-native environments, ensuring high-performance real-time processing while minimizing resource overhead. See the Flink 2.0.0 Release Note .
For best performance on Arm, the Arm Ecosystem Dashboard recommends using Flink ≥ 2.0.0.
Untar the archive:
sudo tar -xvzf flink-2.1.1-bin-scala_2.12.tgz
After extraction, you will have a directory named flink-2.1.1 under /opt.
Rename it for convenience:
sudo mv flink-2.1.1 /opt/flink
This makes configuration, upgrades, and scripting easier for your Flink installation.
Add Flink to your shell environment:
echo "export FLINK_HOME=/opt/flink" >> ~/.bashrc
echo "export PATH=\$FLINK_HOME/bin:\$PATH" >> ~/.bashrc
Create a logging directory and assign proper permissions:
sudo mkdir -p /opt/flink/log
sudo chown -R $(whoami):$(id -gn) /opt/flink/log
sudo chmod -R 755 /opt/flink/log
Apply the changes:
source ~/.bashrc
Adding Flink to the global PATH lets you use commands like flink, start-cluster.sh, and taskmanager.sh from any terminal.
To confirm that Flink has been installed correctly, check its version:
flink -v
You should see an output similar to:
Version: 2.1.1, Commit ID: 074f8c5
Apache Flink is now installed and ready for use.
