In this section you will perform baseline testing for Apache Flink after installation on a GCP SUSE VM. Baseline testing validates that your installation is correct, the JVM is functioning properly, and Flink’s JobManager/TaskManager can execute jobs successfully.
Before running Flink jobs, ensure that Maven is installed on your VM. Many Flink examples and real-world jobs require Apache Maven to compile Java applications.
Install Maven
cd /opt
sudo wget https://archive.apache.org/dist/maven/maven-3/3.8.6/binaries/apache-maven-3.8.6-bin.tar.gz
sudo tar -xvzf apache-maven-3.8.6-bin.tar.gz
sudo mv apache-maven-3.8.6 /opt/maven
Configure environment variables
Configure the environment so Maven commands can be run system-wide:
echo "export M2_HOME=/opt/maven" >> ~/.bashrc
echo "export PATH=\$M2_HOME/bin:\$PATH" >> ~/.bashrc
source ~/.bashrc
Verify the Maven installation:
mvn -version
The output is similar to:
        pache Maven 3.8.6 (84538c9988a25aec085021c365c560670ad80f63)
Maven home: /opt/maven
Java version: 17.0.13, vendor: N/A, runtime: /usr/lib64/jvm/java-17-openjdk-17
Default locale: en, platform encoding: UTF-8
OS name: "linux", version: "5.14.21-150500.55.124-default", arch: "aarch64", family: "unix"
Before launching Flink, open port 8081 in the Google Cloud Firewall Rules so that the Web UI is reachable externally.
cd $FLINK_HOME
./bin/start-cluster.sh
        Starting cluster.
[INFO] 1 instance(s) of standalonesession are already running on lpprojectsusearm64.
Starting standalonesession daemon on host lpprojectsusearm64.
Starting taskexecutor daemon on host lpprojectsusearm64.
Verify that the Flink processes (JobManager and TaskManager) are running:
jps
        21723 StandaloneSessionClusterEntrypoint
2621 Jps
2559 TaskManagerRunner
StandaloneSessionClusterEntrypoint is the JobManager process, and TaskManagerRunner is the worker responsible for executing tasks and maintaining state.
In a browser, navigate to http://<VM_IP>:8081.
You should see the Flink Dashboard:
Image Alt Text:Screenshot of the Apache Flink Dashboard web interface showing the Overview page with cluster status, available task slots, running jobs count, and system metrics displayed in a clean web UI alt-textFlink Dashboard
A successfully loaded dashboard confirms the cluster network and UI functionality. This serves as the baseline for network and UI validation.
Run a simple example job
A basic check is to run the built-in WordCount example:
cd $FLINK_HOME
./bin/flink run examples/streaming/WordCount.jar
You can monitor the job in the Web UI or check console logs.
Image Alt Text:Screenshot of the Flink Dashboard showing a completed WordCount job with execution details, task metrics, and job timeline visible in the web interface alt-textWordCount job in Flink Dashboard
Flink baseline testing is complete. You can now proceed to Flink benchmarking.
