Build an ephemeral AI code sandbox with Firecracker on Arm
Understand the sandbox architecture
Prepare the Arm KVM host
Run code in a disposable microVM
Validate the execution boundaries
Download the sandbox runner
Continuing in the ~/firecracker-ai-sandbox directory, create the runner directories:
mkdir -p sandbox/examples
Download the runner and example programs:
BASE_URL=https://raw.githubusercontent.com/ArmDeveloperEcosystem/arm-learning-paths/main/content/learning-paths/servers-and-cloud-computing/firecracker-ai-sandbox
for FILE in 00-common.sh run-job.sh demo.sh; do
wget -q "$BASE_URL/files/sandbox/$FILE" -O "sandbox/$FILE"
done
for FILE in hello-arm.sh write-marker.sh timeout.sh; do
wget -q "$BASE_URL/files/sandbox/examples/$FILE" -O "sandbox/examples/$FILE"
done
chmod +x sandbox/*.sh sandbox/examples/*.sh
Verify that the downloads completed successfully before running the scripts as root. The command lists the files in the sandbox/ directory, including the sandbox/examples/ subdirectory:
find "$PWD/sandbox" -maxdepth 2 -type f -name "*.sh" -printf "%P\n" | sort
The expected output is:
00-common.sh
demo.sh
examples/hello-arm.sh
examples/timeout.sh
examples/write-marker.sh
run-job.sh
Run the first job
Use the provided hello-arm.sh program to see how a sandbox can execute code submitted by an AI coding agent. This Bash program reports the guest architecture, kernel, CPU count, and memory. The runner copies the program into a fresh microVM and runs it with /bin/bash.
The program uses tools already installed in the base image. Jobs can’t rely on outbound IPv4 access to install dependencies.
Start a microVM and execute the architecture inspection program:
sudo ./sandbox/run-job.sh ./sandbox/examples/hello-arm.sh
The output is similar to:
Job: 20260928T140000Z-12345
Resources: 1 vCPU, 512 MiB, 15s timeout
Cloning a disposable root filesystem...
Booting the microVM...
Executing inside the microVM...
--- stdout ---
Hello from an ephemeral AI code-execution sandbox
architecture=aarch64
kernel=6.1.186
cpus=1
--- result ---
job_id=20260928T140000Z-12345
outcome=succeeded
exit_code=0
The kernel version and job identifier can differ. The important values are architecture=aarch64, cpus=1, outcome=succeeded, and exit_code=0.
After the result is printed, the cleanup trap stops Firecracker and removes the job’s TAP device and writable root filesystem.
Inspect retained results
List the result directories on the host:
sudo find /opt/firecracker-ai/results -mindepth 1 -maxdepth 1 -type d -printf "%f\n"
Identify the most recent result and inspect its metadata:
RESULT_DIR=$(sudo find /opt/firecracker-ai/results -mindepth 1 -maxdepth 1 -type d -printf '%T@ %p\n' | sort -nr | head -n1 | cut -d' ' -f2-)
sudo cat "$RESULT_DIR/result.env"
After the runner reaches the execution phase and writes its result, the result directory contains:
stdout: output written by the guest programstderr: errors written by the guest program or SSHserial.log: Firecracker guest serial outputresult.env: outcome, exit code, duration, source hash, and resource settings
Keep the source file unchanged until the runner exits. The runner computes its SHA-256 hash after execution, so editing the host file during a job can make the recorded hash differ from the program copied into the guest.
The duration_ms field measures the host-side SSH execution phase, excluding disk preparation, guest boot, file transfer, and cleanup. If startup fails, result.env might not exist. Inspect the retained serial.log for boot errors and check for conflicting routes or host firewall rules if SSH cannot connect.
Change the resource limits
Set environment variables before run-job.sh to change the Firecracker resources and timeout:
sudo FC_VCPUS=2 FC_MEM_MIB=1024 FC_JOB_TIMEOUT=30 \
The job receives two virtual CPUs, 1,024 MiB of memory, and a 30-second timeout. These settings apply only to this execution.
The memory allocation includes the guest operating system, so the program has less memory available. The virtual CPU count controls guest CPUs but doesn’t set a host CPU quota. The execution timeout starts after boot and file transfer, so the total elapsed time is longer.
You’ve executed a program on native Arm inside a job-specific microVM and inspected the host-side audit artifacts.
Next, you’ll prove that filesystem changes don’t persist and that the host enforces the execution timeout.
