Build an ephemeral AI code sandbox with Firecracker on Arm
Understand the sandbox architecture
Prepare the Arm KVM host
Run code in a disposable microVM
Validate the execution boundaries
Confirm the host environment
The Learning Path was validated on a platform powered by the Arm AGI CPU and running Ubuntu 24.04.
You can also run the steps on another Arm-based bare-metal server with kernel-based virtual machine (KVM) available as /dev/kvm. For example, you can use an
AWS Graviton4-based Amazon EC2 R8g bare-metal instance
, such as r8g.metal-24xl or r8g.metal-48xl. Select an Ubuntu 24.04 Arm64 image when provisioning the instance.
A VM works only when its platform exposes nested virtualization and /dev/kvm to the guest. Confirm KVM access before continuing.
Ensure the following:
- Run all commands in a Bash shell on this host. You need
sudoaccess andwgetfor the initial downloads. - Use a dedicated test machine because setup scripts install packages. Each job temporarily changes the host’s networking and firewall rules.
- Make sure that the sandbox subnet,
172.16.0.0/30, doesn’t overlap with any network used by the host or its VPN.
Check that you’re running on an Arm-based Linux machine:
uname -m
The expected output is:
aarch64
Confirm that the KVM device exists and is accessible to a privileged process:
sudo test -r /dev/kvm && sudo test -w /dev/kvm && echo "KVM is available"
KVM is available
If the command produces no output, check that the host kernel enables KVM and that /dev/kvm is accessible through sudo. On a VM, also check whether the platform supports nested virtualization.
Download the host preparation scripts
Create a working directory for the sandbox and navigate to it:
mkdir -p ~/firecracker-ai-sandbox
cd ~/firecracker-ai-sandbox
Run all subsequent commands in the ~/firecracker-ai-sandbox directory.
Start by creating a subdirectory called base/ and downloading scripts that install Firecracker and prepare the guest. 00-common.sh holds their shared paths and version settings:
mkdir base
BASE_URL=https://raw.githubusercontent.com/ArmDeveloperEcosystem/arm-learning-paths/main/content/learning-paths/servers-and-cloud-computing/firecracker-ai-sandbox
for FILE in 00-common.sh 01-setup-host.sh 02-prepare-guest.sh; do
wget -q "$BASE_URL/files/base/$FILE" -O "base/$FILE"
done
chmod +x base/*.sh
Verify that the downloads completed successfully before running the scripts as root. The command lists the files in the base/ directory:
find "$PWD/base" -maxdepth 1 -type f -name "*.sh" -printf "%f\n" | sort
00-common.sh
01-setup-host.sh
02-prepare-guest.sh
Install Firecracker
Run the host setup script:
sudo ./base/01-setup-host.sh
The script performs the following tasks:
- Confirms that the host uses
aarch64and exposes/dev/kvm - Installs the Ubuntu packages needed for Firecracker, guest preparation, networking, and SSH
- Downloads the pinned
aarch64Firecracker release - Installs
firecrackerandjailerunder/usr/local/bin
Confirm the installed version:
firecracker --version
The output is similar to:
Firecracker v1.15.1
Prepare the reusable guest image
Create the Arm guest artifacts:
sudo ./base/02-prepare-guest.sh
The script downloads an Arm64 Linux kernel and Ubuntu 24.04 root filesystem from the Firecracker continuous integration (CI) artifacts. It converts the compressed, read-only SquashFS image into a 5 GB writable ext4 image, then configures SSH and a static private network.
Preparation uses chroot to run Arm64 guest provisioning commands on your Arm host. It installs guest packages using the host’s network access; the job firewall rules aren’t active during this step. Allow disk space for the downloaded image, temporary extracted files, the base disk, and one disposable job disk.
Firecracker and the guest kernel version are pinned in base/00-common.sh, but the script selects a dated CI artifact directory dynamically. Those artifacts can change independently of the Firecracker release.
List the resulting artifacts:
sudo ls -lh /opt/firecracker-lp/artifacts
Confirm that the artifacts directory contains the following key files:
vmlinux: the uncompressed Arm guest kernelrootfs.ext4: the reusable base root filesystemid_rsa: the host-side private SSH keyid_rsa.pub: the public key installed in the guest
Despite the file name id_rsa, the script generates an Ed25519 key. Keep the private key on the host. The runner uses the key to copy and execute programs over SSH. You don’t need to open a public SSH port for the microVM.
Treat /opt/firecracker-lp/artifacts/rootfs.ext4 as a clean baseline. The job runner copies it before every execution and never boots the baseline directly.
You’ve installed Firecracker and created the guest artifacts shared by all jobs.
Next, you’ll download the runner and execute a shell program inside a disposable microVM.
