Get started with Envoy Proxy on Google Axion C4A (Arm Neoverse V2)
Create a Google Axion C4A Arm virtual machine on GCP
Deploy Envoy on Google Axion C4A Arm virtual machines
Run baseline Envoy testing on a Google Axion C4A Arm VM
Benchmark Envoy on Google Cloud for Arm64 and x86_64 with Siege
In this section you’ll install Envoy Proxy v1.30.0 on a Google Cloud Axion C4A virtual machine running RHEL 9. You’ll install the dependencies, download the official static Arm64 Envoy binary, and verify the installation.
sudo dnf install -y \
autoconf \
curl \
libtool \
patch \
python3 \
python3-pip \
unzip \
git
pip3 install virtualenv
Download the Envoy binary. -L follows redirects:
sudo curl -L \
-o /usr/local/bin/envoy \
https://github.com/envoyproxy/envoy/releases/download/v1.30.0/envoy-1.30.0-linux-aarch_64
Change the permissions on the downloaded binary to make it an executable:
sudo chmod +x /usr/local/bin/envoy
Verify the installation by checking its version:
envoy --version
This confirms the binary is correctly placed and executable.
Expected output:
envoy version: 50ea83e602d5da162df89fd5798301e22f5540cf/1.30.0/Clean/RELEASE/BoringSSL
Envoy is now installed. Continue to baseline testing in the next section.
