Get started with Envoy Proxy on Google Axion C4A (Arm Neoverse V2)
Create a Google Axion C4A Arm virtual machine on GCP
Deploy Envoy on Google Axion C4A Arm virtual machines
Run baseline Envoy testing on a Google Axion C4A Arm VM
Benchmark Envoy on Google Cloud for Arm64 and x86_64 with Siege
Siege is a lightweight HTTP load testing and benchmarking tool that simulates concurrent users making requests to a target service. It is useful for Envoy benchmarking because it measures availability, throughput, response time, and failure rates under load, thus helping evaluate Envoy’s performance as a proxy under real-world traffic conditions.
Follow the steps outlined to run Envoy benchmarks using Siege.
Install required build tools:
sudo dnf groupinstall -y "Development Tools"
sudo dnf install -y wget make gcc
Download, extract and build Siege source:
wget http://download.joedog.org/siege/siege-4.1.6.tar.gz
tar -xvzf siege-4.1.6.tar.gz
cd siege-4.1.6
./configure
make
sudo make install
You have now successfully built and installed Siege on your Arm-based machine.
Verify installation:
siege --version
This checks if Siege is installed properly and shows the version number:
SIEGE 4.1.6
Copyright (C) 2023 by Jeffrey Fulmer, et al.
This is free software; see the source for copying conditions.
There is NO warranty; not even for MERCHANTABILITY or FITNESS
FOR A PARTICULAR PURPOSE.
To start, make sure Envoy is up and running with your config file (listening on port 10000):
envoy -c envoy_config.yaml --base-id 1
This runs the Envoy proxy with your configuration file (envoy_config.yaml) so it can start listening for requests.
On another terminal, verify that Envoy is running as expected with curl:
curl -v http://127.0.0.1:10000/get
Running from another terminal returns a 200 OK status, confirming that Envoy is running and successfully processing requests.
There are different ways you can set up your benchmark tests. Here, you will run a benchmark for a fixed time instead of using a request count:
siege -c30 -t10S http://127.0.0.1:10000/get
This runs a load test where 30 users hit Envoy continuously for 10 seconds. After this, Siege will show performance results.
The output should show a list of HTTP requests and responses followed by a summary as shown:
HTTP/1.1 200 0.03 secs: 383 bytes ==> GET /get
HTTP/1.1 200 0.02 secs: 383 bytes ==> GET /get
HTTP/1.1 200 0.42 secs: 383 bytes ==> GET /get
HTTP/1.1 200 1.17 secs: 383 bytes ==> GET /get
HTTP/1.1 200 0.81 secs: 383 bytes ==> GET /get
HTTP/1.1 200 0.14 secs: 383 bytes ==> GET /get
Lifting the server siege...
Transactions: 1019 hits
Availability: 99.80 %
Elapsed time: 10.38 secs
Data transferred: 0.37 MB
Response time: 0.29 secs
Transaction rate: 98.17 trans/sec
Throughput: 0.04 MB/sec
Concurrency: 28.07
Successful transactions: 1019
Failed transactions: 2
Longest transaction: 2.89
Shortest transaction: 0.02
To compare the benchmark results, the following were collected by running the same benchmark on a c3-standard-4 (4 vCPU, 16 GB memory) x86_64 VM in GCP, running RHEL 9:
| Metric | Value | Metric | Value |
| Transactions | 720 hits | Availability | 98.90 % |
| Elapsed time | 10.98 secs | Data transferred | 0.26 MB |
| Response time | 0.44 secs | Transaction rate | 65.57 trans/sec |
| Throughput | 0.02 MB/sec | Concurrency | 28.66 |
| Successful transactions | 720 | Failed transactions | 8 |
| Longest transaction | 4.63 secs | Shortest transaction | 0.02 secs |
Results from the earlier run on the c4a-standard-4 (4 vCPU, 16 GB memory) Arm64 VM in GCP (RHEL 9):
| Transactions | 1019 hits | Availability | 99.80 % |
| Elapsed time | 10.38 secs | Data transferred | 0.37 MB |
| Response time | 0.29 secs | Transaction rate | 98.17 trans/sec |
| Throughput | 0.04 MB/sec | Concurrency | 28.07 |
| Successful transactions | 1019 | Failed transactions | 2 |
| Longest transaction | 2.89 secs | Shortest transaction | 0.02 secs |
When you compare the benchmarking performance results between the two instance types with the same vCPUs, you will notice that on the Google Axion C4A Arm-based instances:
You have successfully learned how to use Siege to benchmark Envoy on your Arm-based Axion Google cloud instance, validating both performance and reliability against similar x86_64 instances.
