Get started with Envoy Proxy on Google Axion C4A (Arm Neoverse V2)
Create a Google Axion C4A Arm virtual machine on GCP
Deploy Envoy on Google Axion C4A Arm virtual machines
Run baseline Envoy testing on a Google Axion C4A Arm VM
Benchmark Envoy on Google Cloud for Arm64 and x86_64 with Siege
With Envoy installed successfully on your GCP C4A Arm virtual machine, you can now validate that Envoy is running as expected.
In this section, you will do the following:
curlThe test confirms the following:
httpbin.orgUsing a text editor, create a file named envoy_config.yaml and add the following content as shown below.
static_resources:
listeners:
- name: listener_0
address:
socket_address:
protocol: TCP
address: 0.0.0.0
port_value: 10000
filter_chains:
- filters:
- name: envoy.filters.network.http_connection_manager
typed_config:
"@type": type.googleapis.com/envoy.extensions.filters.network.http_connection_manager.v3.HttpConnectionManager
stat_prefix: ingress_http
route_config:
virtual_hosts:
- name: backend
domains: ["*"]
routes:
- match:
prefix: "/"
route:
cluster: service_httpbin
host_rewrite_literal: httpbin.org
http_filters:
- name: envoy.filters.http.router
typed_config:
"@type": type.googleapis.com/envoy.extensions.filters.http.router.v3.Router
clusters:
- name: service_httpbin
connect_timeout: 0.5s
type: LOGICAL_DNS
dns_lookup_family: V4_ONLY
lb_policy: ROUND_ROBIN
load_assignment:
cluster_name: service_httpbin
endpoints:
- lb_endpoints:
- endpoint:
address:
socket_address:
address: httpbin.org
port_value: 80
This configures Envoy to listen on port 10000 and forward all traffic to http://httpbin.org. The host_rewrite_literal is required to prevent 404 Not Found from the upstream server.
service_httpbin cluster, with the Host header rewritten to httpbin.org.service_httpbin cluster defines the upstream as httpbin.org:80.This is the final phase of functional validation, confirming that the proxy is operational. Start the Envoy proxy using your configuration file:
envoy -c envoy_config.yaml --base-id 1
The output should look similar to:
[2025-08-21 11:53:51.597][67137][info][config] [source/server/configuration_impl.cc:138] loading 1 listener(s)
[2025-08-21 11:53:51.597][67137][info][config] [source/server/configuration_impl.cc:154] loading stats configuration
[2025-08-21 11:53:51.598][67137][warning][main] [source/server/server.cc:928] There is no configured limit to the number of allowed active downstream connections. Configure a limit in `envoy.resource_monitors.downstream_connections` resource monitor.
[2025-08-21 11:53:51.598][67137][info][main] [source/server/server.cc:969] starting main dispatch loop
[2025-08-21 11:53:51.599][67137][info][runtime] [source/common/runtime/runtime_impl.cc:614] RTDS has finished initialization
[2025-08-21 11:53:51.599][67137][info][upstream] [source/common/upstream/cluster_manager_impl.cc:240] cm init: all clusters initialized
[2025-08-21 11:53:51.599][67137][info][main] [source/server/server.cc:950] all clusters initialized. initializing init manager
[2025-08-21 11:53:51.599][67137][info][config] [source/common/listener_manager/listener_manager_impl.cc:930] all dependencies initialized. starting workers
Leave this terminal running. In a new terminal, send a test request to the Envoy listener using curl:
curl -v http://localhost:10000/get
The -v flag provides verbose output, showing the full request and response headers. A successful test will show a HTTP/1.1 200 OK response with a JSON body from httpbin.org.
A successful test shows HTTP/1.1 200 OK with a JSON body from httpbin.org, for example:
* Trying 127.0.0.1:10000...
* Connected to 127.0.0.1 (127.0.0.1) port 10000 (#0)
> GET /get HTTP/1.1
> Host: 127.0.0.1:10000
> User-Agent: curl/7.76.1
> Accept: */*
* Mark bundle as not supporting multiuse
< HTTP/1.1 200 OK
< date: Fri, 22 Aug 2025 11:20:35 GMT
< content-type: application/json
< content-length: 301
< server: envoy
< access-control-allow-origin: *
< access-control-allow-credentials: true
< x-envoy-upstream-service-time: 1042
"args": {},
"headers": {
"Accept": "*/*",
"Host": "httpbin.org",
"User-Agent": "curl/7.76.1",
"X-Amzn-Trace-Id": "Root=1-68a85282-10af9cfe0385774600509ddd",
"X-Envoy-Expected-Rq-Timeout-Ms": "15000"
"origin": "34.63.220.63",
"url": "http://httpbin.org/get"
* Connection #0 to host 127.0.0.1 left intact
curl command successfully connected to the Envoy proxy on localhost:10000.200 OK response from the upstream.Host to httpbin.org as configured.To stop Envoy in the first terminal, press Ctrl+C. This confirms the end-to-end flow with Envoy server is working correctly.
