Explore related resources
Give feedback
AI-assisted
Close
Which Azure VM size should I choose for this deployment?
Use a memory-optimized VM in the Epdsv6 series with the Arm-based Cobalt 100 processor. You configure this instance through the Azure portal.
Do I need Java, and which version should I install?
Yes. Install OpenJDK 21 (openjdk-21-jdk) because Elasticsearch needs it.
Should I run ESRally on the same VM as Elasticsearch?
Yes. Install both Elasticsearch and ESRally on the same Cobalt 100 VM.
What should I check to confirm Elasticsearch is ready before benchmarking?
Ensure the service starts without errors and is ready to accept connections. Proceed to ESRally only after the service is running and healthy.
Which ESRally track should I run, and what results should I focus on?
Run the geonames track. Focus on key metrics reported by ESRally, including indexing throughput and query latency under mixed ingest and search conditions.
