# Build and deploy a multi-arch application on Amazon EKS
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/servers-and-cloud-computing/eks-multi-arch/)
- [Build and deploy a multi-arch application on Amazon EKS](https://learn.arm.com/learning-paths/servers-and-cloud-computing/eks-multi-arch/go-multi-arch-eks/)
- [Next Steps](https://learn.arm.com/learning-paths/servers-and-cloud-computing/eks-multi-arch/_next-steps/)
## Multi-architecture Amazon EKS cluster with x86 and Arm-based (Graviton) nodes
A multi-architecture Kubernetes cluster runs workloads on multiple hardware architectures, typically arm64 and amd64. To learn more about multi-architecture Kubernetes, you can create a hybrid cluster in Amazon EKS and gain some practical experience with arm64 and amd64 nodes. This will also help you understand multi-architecture container images.
## Before you begin
You will need an [AWS account](https://aws.amazon.com/). Create an account if needed.
Three tools are required on your local machine. Follow the links to install the required tools.
- [Kubectl](https://learn.arm.com/install-guides/kubectl/)
- [Amazon eksctl CLI](https://learn.arm.com/install-guides/eksctl/)
- [Docker](https://learn.arm.com/install-guides/docker/)
## Create a multi-architecture Amazon EKS Cluster
Use `eksctl` to create a multi-architecture Amazon EKS cluster. Create a file named `cluster.yaml` with the contents below using a file editor of your choice.
```yaml
apiVersion: eksctl.io/v1alpha5
kind: ClusterConfig
metadata:
  region: us-east-1
nodeGroups:
  - name: x86-node-group
    instanceType: m5.large
    desiredCapacity: 2
    volumeSize: 80
  - name: arm64-node-group
    instanceType: m6g.large
    desiredCapacity: 2
    volumeSize: 80
Run the `eksctl` command to create the EKS cluster:
```bash
eksctl create cluster -f cluster.yaml
This command will create a cluster that has 2 x86/amd64 nodes and 2 arm64 nodes. When the cluster is ready, use the following command to check the nodes:
```bash
kubectl get nodes
The output should look similar to:
```plaintext
NAME                                          STATUS   ROLES    AGE     VERSION
ip-172-31-10-206.eu-west-1.compute.internal   Ready    <none>   9m56s   v1.28.1-eks-43840fb
ip-172-31-16-133.eu-west-1.compute.internal   Ready    <none>   9m59s   v1.28.1-eks-43840fb
ip-172-31-19-140.eu-west-1.compute.internal   Ready    <none>   8m32s   v1.28.1-eks-43840fb
ip-172-31-40-45.eu-west-1.compute.internal    Ready    <none>   8m32s   v1.28.1-eks-43840fb
To check the architecture of the nodes, execute the following command:
```bash
kubectl get node -o jsonpath='{.items[*].status.nodeInfo.architecture}'
The output should show two architectures for four nodes:
```plaintext
arm64 amd64 amd64 arm64
## Multi-architecture containers
Multi-architecture container images are the easiest way to deploy applications and hide the underlying hardware architecture. Building multi-architecture images is slightly more complex compared to building single-architecture images. Docker provides two ways to create multi-architecture images:
- `docker buildx` - builds both architectures at the same time.
- `docker manifest` - builds each architecture separately and joins them together into a multi-architecture image.
Shown below is a simple `Go` application you can use to learn about multi-architecture Kubernetes clusters. Create a file named `hello.go` with the contents below:
```go
package main
import (
    "fmt"
    "log"
    "net/http"
    "os"
    "runtime"
func handler(w http.ResponseWriter, r *http.Request) {
    fmt.Fprintf(w, "Hello from image NODE:%s, POD:%s, CPU PLATFORM:%s/%s",
        os.Getenv("NODE_NAME"), os.Getenv("POD_NAME"), runtime.GOOS, runtime.GOARCH)
func main() {
    http.HandleFunc("/", handler)
    log.Fatal(http.ListenAndServe(":8080", nil))
Create another file named `go.mod` with the following content:
```plaintext
module example.com/arm
go 1.21
Create a Dockerfile with the following content:
```dockerfile
ARG T
# Build: 1st stage
FROM golang:1.21-alpine as builder
ARG TARCH
WORKDIR /app
COPY go.mod .
COPY hello.go .
RUN GOARCH=${TARCH} go build -o /hello && \
    apk add --update --no-cache file && \
    file /hello
# Release: 2nd stage
FROM ${T}alpine
WORKDIR /
COPY --from=builder /hello /hello
RUN apk add --update --no-cache file
CMD [ "/hello" ]
## Build multi-architecture docker images with docker buildx
With these files you can build your docker image. Log in to Amazon ECR and create a repository named `multi-arch-app`.
Run the following command to build and push the docker image to the repository:
```bash
docker buildx create --name multiarch --use --bootstrap
docker buildx build -t <your-docker-repo-path>/multi-arch:latest --platform linux/amd64,linux/arm64 --push .
Replace `<your-docker-repo-path>` in the command above to the location of your repository. You should now see the docker image in your repository.
## Build multi-architecture docker images with docker manifest
You can also use docker manifest to create a multi-architecture image from two single-architecture images. Create another repository in Amazon ECR with the name `multi-arch-demo`. Use the following command to build an amd64 image:
```bash
docker build build -t <your-docker-repo-path>/multi-arch-demo:amd64 --build-arg TARCH=amd64 --build-arg T=amd64/ .
docker push <your-docker-repo-path>/multi-arch-demo:amd64
Build an arm64 image by executing the following commands on an arm64 machine:
```bash
docker build build -t <your-docker-repo-path>/multi-arch-demo:arm64 --build-arg TARCH=amd64 --build-arg T=amd64v8/ .
docker push <your-docker-repo-path>/multi-arch-demo:arm64
Again, replace `<your-docker-repo-path>` in the commands above to the location of your repository.
After building individual containers for each architecture, merge them into a single image by running the commands below on either architecture:
```bash
docker manifest create <your-docker-repo-path>/multi-arch-demo:latest \
--amend <your-docker-repo-path>/multi-arch-demo:arm64 \
--amend <your-docker-repo-path>/multi-arch-demo:amd64
docker manifest push --purge <your-docker-repo-path>/multi-arch-demo:latest
You should see three images in the ECR repository - one for each architecture (amd64 and arm64) and a combined multi-architecture image.
## Deploy Kubernetes service in EKS cluster
You can now create a service to deploy the application. Create a file named `hello-service.yaml` with the following contents:
```yaml
apiVersion: v1
kind: Service
metadata:
  labels:
    app: hello
    tier: web
spec:
  type: LoadBalancer
  ports:
    - port: 80
      targetPort: 8080
  selector:
    app: hello
    tier: web
Deploy the service and run the following command:
```bash
kubectl apply -f hello-service.yaml
## Deploy amd64 application
Create a text file named `amd64-deployment.yaml` with the contents below. The amd64 image will only run on amd64 nodes. The nodeSelector is used to make sure the container is only scheduled on amd64 nodes.
```yaml
apiVersion: apps/v1
kind: Deployment
metadata:
  labels:
    app: hello
spec:
  replicas: 1
  selector:
    matchLabels:
      app: hello
      tier: web
  template:
    metadata:
      labels:
        app: hello
        tier: web
    spec:
      containers:
      - name: hello
        image: <your-docker-repo-path>/multi-arch-demo:amd64
        imagePullPolicy: Always
        ports:
          - containerPort: 8080
        env:
          - name: NODE_NAME
            valueFrom:
              fieldRef:
                fieldPath: spec.nodeName
          - name: POD_NAME
            valueFrom:
              fieldRef:
                fieldPath: metadata.name
        resources:
          requests:
            cpu: 300m
      nodeSelector:
        kubernetes.io/arch: amd64
Use the following command to deploy the application:
```bash
kubectl apply -f amd64-deployment.yaml
The output should show a single pod running.
Get the external IP assigned to the service you deployed earlier, by executing the following command:
```bash
kubectl get svc
Use the `external-ip` from the command output and execute the following command (this IP belongs to the Load Balancer provisioned in your cluster):
```bash
curl -w '\n' http://<external_ip>
You should now see an output similar to what’s shown below:
```plaintext
Hello from image NODE:ip-192-168-32-244.ec2.internal, POD:amd-deployment-7d4d44889d-vzhpd, CPU PLATFORM:linux/amd64
## Deploy arm64 application
Create a text file named `arm64-deployment.yaml` with the contents below. Note that the value of `nodeSelector` is now arm64.
```yaml
apiVersion: apps/v1
kind: Deployment
metadata:
  labels:
    app: hello
spec:
  replicas: 1
  selector:
    matchLabels:
      app: hello
      tier: web
  template:
    metadata:
      labels:
        app: hello
        tier: web
    spec:
      containers:
      - name: hello
        image: <your-docker-repo-path>/multi-arch-demo:arm64
        ports:
        env:
          - name: NODE_NAME
            valueFrom:
              fieldRef:
          - name: POD_NAME
            valueFrom:
              fieldRef:
        resources:
          requests:
            cpu: 300m
      nodeSelector:
        kubernetes.io/arch: arm64
Deploy the arm64 application by using the command below:
```bash
kubectl apply -f arm64-deployment.yaml
Execute the following command to check the running pods:
```bash
kubectl get pods
You should now see two pods running in the cluster, one for amd64 and another one for arm64. Execute the curl command a few times to see output from both the pods; you should see responses from both the arm64 and amd64 pods.
```bash
## Deploy multi-architecture application in EKS cluster
You can now deploy the multi-architecture version of the application in EKS cluster. Create a text file named `multi-arch-deployment.yaml` with the contents below. The image is the multi-architecture image created with docker buildx and 6 replicas are specified.
```yaml
apiVersion: apps/v1
kind: Deployment
metadata:
  labels:
    app: hello
spec:
  replicas: 6
  selector:
    matchLabels:
      app: hello
      tier: web
  template:
    metadata:
      labels:
        app: hello
        tier: web
    spec:
      containers:
      - name: hello
        image: <your-docker-repo-path>/multi-arch:latest
        ports:
        env:
          - name: NODE_NAME
            valueFrom:
              fieldRef:
          - name: POD_NAME
            valueFrom:
              fieldRef:
        resources:
          requests:
            cpu: 300m
Deploy the multi-architecture application by using the command below:
```bash
kubectl apply -f multi-arch-deployment.yaml
```bash
kubectl get pods
The output should show all the pods from three deployments. To test the application, run the following command to check messages from all three versions of the application:
```bash
for i in $(seq 1 10); do curl -w '\n' http://<external_ip>; done
The output will show a variety of arm64 and amd64 messages.
You have now deployed an x86/amd64, arm64 and multi-architecture version of the same application in a single Amazon EKS cluster. Leverage these techniques to incrementally migrate your existing x86/amd64 based applications to arm64 in AWS.
