Deploy a container on AWS Graviton with ECS Managed Instances
Set up IAM roles and an Arm-compatible task definition
Create a capacity provider for Graviton-based instances
Run a container as an Amazon ECS task on AWS Graviton
Clean up AWS resources
Remove AWS resources in order
Remove the resources that you created to avoid ongoing charges. You can’t delete a cluster while a cluster-scoped capacity provider is still attached. You can’t delete a capacity provider while it’s part of the cluster’s default capacity provider strategy, or has running tasks.
Clean up resources in the following order:
- Stop the running task.
- Delete the capacity provider.
- Delete the cluster.
- Deregister and delete the task definition.
You can clean up resources using either the AWS Management Console or the AWS CLI.
First, stop the running task.
Use the AWS Management Console
To stop the task using the console:
- Navigate to the console for Amazon ECS .
- Select Clusters.
- Select the cluster ecs-managed-instances-cluster that you created earlier.
- Select Tasks.
- Select the running task.
- Select Stop, then select Stop selected.
Use the AWS CLI
Find the running task Amazon Resource Name (ARN), then use the ARN to stop it:
TASK_ARN=$(aws ecs list-tasks --cluster ecs-managed-instances-cluster --query 'taskArns[0]' --output text)
aws ecs stop-task --cluster ecs-managed-instances-cluster --task "$TASK_ARN"
Next, delete the ECS Managed Instances capacity provider. Deleting the capacity provider deprovisions and terminates the compute.
To delete the capacity provider using the console:
- Select Clusters.
- Select the cluster ecs-managed-instances-cluster.
- Select Actions, then select Update cluster.
- Locate the capacity provider for ECS Managed Instances under Cluster configuration, and select Remove.
- Select Update.
- Select Infrastructure.
- Under Capacity providers, select the capacity provider for ECS Managed Instances, then select Delete. Deletion can take a few minutes.
Use the AWS CLI
Find the name of the capacity provider that’s associated with the cluster:
aws ecs describe-clusters \
--clusters ecs-managed-instances-cluster \
--query 'clusters[0].capacityProviders' \
--output text
The capacity provider is part of the cluster’s default capacity provider strategy. Clear the default strategy before deleting the capacity provider:
aws ecs put-cluster-capacity-providers \
--cluster ecs-managed-instances-cluster \
--capacity-providers `[]` \
--default-capacity-provider-strategy `[]`
Then, delete the capacity provider, replacing <capacity-provider-name> with the name from the earlier command:
aws ecs delete-capacity-provider \
--capacity-provider <capacity-provider-name> \
It can take a few minutes to reach DELETE_COMPLETE.
Delete the cluster
After deleting the capacity provider, delete the cluster.
To delete the cluster using the console:
- Select Clusters.
- Select Actions, then select Delete cluster.
Use the AWS CLI
Run the following command to delete the cluster using the CLI:
aws ecs delete-cluster --cluster ecs-managed-instances-cluster
Finally, you can deregister and delete the task definition.
To deregister and delete the task definition using the console:
- Select Task definitions.
- Select the nginx task definition that you created earlier.
- Select the task definition revision, for example nginx:1.
- Select Deregister.
- After the task definition revision is deregistered, select Delete.
Use the AWS CLI
Run the following command to deregister and delete the task definition using the CLI:
aws ecs deregister-task-definition --task-definition nginx:1
aws ecs delete-task-definitions --task-definitions nginx:1
(Optional) Remove the IAM roles
You can also remove the IAM roles and instance profile that you created earlier:
aws iam remove-role-from-instance-profile \
--instance-profile-name ecsInstanceRole \
--role-name ecsInstanceRole
aws iam delete-instance-profile --instance-profile-name ecsInstanceRole
aws iam detach-role-policy \
--role-name ecsInstanceRole \
--policy-arn arn:aws:iam::aws:policy/AmazonECSInstanceRolePolicyForManagedInstances
aws iam delete-role --role-name ecsInstanceRole
--role-name ecsInfrastructureRole \
--policy-arn arn:aws:iam::aws:policy/AmazonECSInfrastructureRolePolicyForManagedInstances
aws iam delete-role --role-name ecsInfrastructureRole
What you’ve accomplished
You’ve cleaned up all resources that you created to test deploying containers on AWS Graviton with Amazon ECS Managed Instances.
You can extend the Learning Path workflow to deploy containers on AWS-managed Arm-based instances powered by AWS Graviton, while maintaining control over the instance types and features that you use.
