Deploy a container on AWS Graviton with ECS Managed Instances
Set up IAM roles and an Arm-compatible task definition
Create a capacity provider for Graviton-based instances
Run a container as an Amazon ECS task on AWS Graviton
Clean up AWS resources
Understand Amazon ECS Managed Instances
Amazon Elastic Container Service (ECS) is a solution for deploying containers on AWS.
Amazon ECS runs your containers as tasks using one of the following compute options:
| Compute option | Who manages the instances | Instance type control | Best for |
| AWS Fargate | AWS (serverless, one isolated environment per task) | None | Workloads that you don’t need to choose instance types for |
| ECS Managed Instances | AWS (provisioning, scaling, patching, maintenance) | Yes, including AWS Graviton | Workloads that need specific EC2 capabilities without managing infrastructure |
| Amazon EC2 launch type | You (instances, scaling, patching, AMIs) | Full | Workloads that need maximum control over the instances |
Amazon ECS Managed Instances is a compute option that sits between AWS Fargate and the Amazon EC2 launch type. AWS manages the infrastructure for you, similar to AWS Fargate. However, you get greater control over the Amazon EC2 features and instance types used to run your containers. This includes the ability to use AWS Graviton-based instance types.
Fargate runs each task in its own isolated environment. By contrast, Amazon ECS Managed Instances can place multiple tasks on a larger instance to improve utilization. For more information about task placement, see How Amazon ECS places tasks on container instances .
Some of the compute attributes that you can control when using ECS Managed Instances include the following:
- vCPU count
- Memory
- Local storage
- Instance type and family
- CPU manufacturer
- Accelerator type
AWS automatically selects an instance based on the compute attributes that you specify. Infrastructure management is handled on your behalf, including software and operating system patching, instance scaling, and maintenance.
You’ll create IAM roles with the AWS CLI and register a task definition with either the AWS CLI or the AWS Management Console. Then, you’ll use either the console or the CLI to create the cluster and capacity provider, and run a task.
Before you begin
Before continuing, ensure that the AWS CLI is installed and configured. Confirm that you can sign in to the AWS Management Console.
Create AWS IAM roles
To use Amazon ECS Managed Instances, you need two IAM roles:
- An infrastructure role that allows Amazon ECS to manage the lifecycle of your managed instances on your behalf.
- An instance role, made available to instances through an instance profile. The Amazon ECS agent assumes this role to register instances with your cluster and communicate with the Amazon ECS service.
Make sure that your credentials have the permission to create IAM roles.
Create the infrastructure role
First, create a file named ecs-infrastructure-trust-policy.json with the following trust policy. The trust policy allows the Amazon ECS service to assume the role:
"Version": "2012-10-17",
"Statement": [
"Sid": "AllowAccessToECSForInfrastructureManagement",
"Effect": "Allow",
"Principal": {
"Service": "ecs.amazonaws.com"
"Action": "sts:AssumeRole"
Next, create a role named ecsInfrastructureRole using the trust policy:
aws iam create-role \
--role-name ecsInfrastructureRole \
--assume-role-policy-document file://ecs-infrastructure-trust-policy.json
Finally, attach the AmazonECSInfrastructureRolePolicyForManagedInstances managed policy to the role:
aws iam attach-role-policy \
--policy-arn arn:aws:iam::aws:policy/AmazonECSInfrastructureRolePolicyForManagedInstances
Create the instance role and instance profile
First, create a file named ecsInstanceRole-trust-policy.json with the following trust policy. The policy allows Amazon EC2 to assume the role:
"Statement": [
"Effect": "Allow",
"Principal": {
"Service": "ec2.amazonaws.com"
Next, create a role named ecsInstanceRole using the trust policy:
--role-name ecsInstanceRole \
--assume-role-policy-document file://ecsInstanceRole-trust-policy.json
Then, attach the AmazonECSInstanceRolePolicyForManagedInstances managed policy to the role:
--policy-arn arn:aws:iam::aws:policy/AmazonECSInstanceRolePolicyForManagedInstances
Finally, create an instance profile, then add the role to it:
aws iam create-instance-profile --instance-profile-name ecsInstanceRole
aws iam add-role-to-instance-profile \
--instance-profile-name ecsInstanceRole \
Verify the roles and instance profile
Confirm that both roles and the instance profile were created successfully:
aws iam get-role --role-name ecsInfrastructureRole --query 'Role.RoleName' --output text
aws iam get-instance-profile --instance-profile-name ecsInstanceRole --query 'InstanceProfile.Roles[0].RoleName' --output text
The commands return ecsInfrastructureRole and ecsInstanceRole.
You’ll use both roles when you create the Amazon ECS cluster.
Register an Arm-compatible Amazon ECS task definition
An Amazon ECS task definition is a blueprint for a containerized application.
To deploy a containerized application on Arm-based AWS compute, register a task definition that supports the ARM64 architecture.
Create a file named nginx-task-def.json with the following contents. The runtimePlatform block sets the architecture to ARM64, and requiresCompatibilities includes MANAGED_INSTANCES:
"family": "nginx",
"containerDefinitions": [
"name": "ecs-managed-instances-graviton-task-def",
"image": "nginx",
"cpu": 0,
"portMappings": [
"containerPort": 80,
"hostPort": 80,
"protocol": "tcp",
"name": "nginx-80-tcp",
"appProtocol": "http"
"essential": true,
"environment": [],
"environmentFiles": [],
"mountPoints": [],
"volumesFrom": [],
"ulimits": [],
"systemControls": []
"networkMode": "host",
"volumes": [],
"placementConstraints": [],
"requiresCompatibilities": [
"MANAGED_INSTANCES"
"cpu": "1024",
"memory": "3072",
"runtimePlatform": {
"cpuArchitecture": "ARM64",
"operatingSystemFamily": "LINUX"
"enableFaultInjection": false
Register the task definition using either the AWS CLI or the AWS Management Console.
Register the task definition using the AWS CLI
Register the task definition from the file:
aws ecs register-task-definition --cli-input-json file://nginx-task-def.json
The command returns the registered task definition, including its family (nginx) and revision number.
Register the task definition using the AWS Management Console
To register the same task definition using the console:
- Navigate to the console for Amazon ECS .
- Select Task definitions.
- Select Create new task definition, then select Create new task definition with JSON.
- Paste the task definition JSON.
- Select Create.
You’ve now learned what Amazon ECS Managed Instances is, created the necessary AWS IAM roles, and registered a task definition that’s compatible with the Arm architecture.
Next, you’ll create an Amazon ECS cluster and a capacity provider that uses compute attributes to select AWS Graviton-based instance types.
