Install Dynatrace OneAgent on Azure Ubuntu Arm64
To install Dynatrace OneAgent on an Azure Ubuntu 24.04 LTS Arm64 virtual machine, follow these steps.
After installation completes, Dynatrace OneAgent:
  • Runs as a host monitoring agent
  • Connects to your Dynatrace SaaS environment
  • Monitors system processes and services automatically
  • Operates natively on Arm64 (aarch64) architecture
Update the system and install required tools
Update the operating system and install the tools required for downloading the Dynatrace installer.
sudo apt update && sudo apt upgrade -y
sudo apt install -y curl wget unzip ca-certificates
Verify Arm64 architecture
Confirm that the virtual machine is running on the Arm64 architecture.
uname -m
The output is similar to:
        aarch64
This confirms the system is using the Arm64 architecture required for Cobalt 100 processors.
Create your Dynatrace trial environment
In a web browser, go to Dynatrace and select Try it free followed by Start trial.
Enter your email and then complete the requested fields:
  • Create and supply a password for your trial account
  • First name
  • Last name
  • Work email address
  • Company name
  • Country
After submitting the form, Dynatrace creates a new SaaS monitoring environment for you.
This process usually takes 1–2 minutes.
Access your Dynatrace environment
After the environment is created, your browser shows a button named Launch Dynatrace. Select it to open your Dynatrace environment.
Make a note of the environment ID assigned to your account because it appears in your dashboard URL.
Example:
https://mbp77458.apps.dynatrace.com/ui/apps/dynatrace.launcher/getting-started
The Environment ID uniquely identifies your Dynatrace tenant and is required for agent installation.
Image Alt Text:Dynatrace environment login page showing SaaS environment URLDynatrace SaaS environment login
From the Dynatrace dashboard:
  • Choose OneAgent
  • Choose Setup
Image Alt Text:Dynatrace deployment page showing OneAgent setup optionsDynatrace OneAgent deployment setup page
This page generates the installation command tailored for your environment.
Select Arm64 architecture
On the installer page, confirm these selections:
  • Platform -> Linux
  • Architecture -> ARM64
  • Monitoring mode -> Full-stack monitoring
Then select Generate token to create an authentication token.
Image Alt Text:Dynatrace installer page showing ARM64 architecture selectionDynatrace OneAgent ARM64 architecture selection
Copy OneAgent installer command
Dynatrace generates an installer command that includes your environment ID and API token.:
wget -O Dynatrace-OneAgent-Linux-arm.sh \
"https://<ENV>.live.dynatrace.com/api/v1/deployment/installer/agent/unix/default/latest?arch=arm" \
--header="Authorization: Api-Token <API_TOKEN>"
Example:
"https://qzo72404.live.dynatrace.com/api/v1/deployment/installer/agent/unix/default/latest?arch=arm" \
--header="Authorization: Api-Token DT_API_TOKEN"
The API token allows secure access to the Dynatrace installer.
Run this command on the virtual machine to download the installer.
Verify installer signature
For security, verify the installer signature using Dynatrace’s root certificate.
wget https://ca.dynatrace.com/dt-root.cert.pem
( echo 'Content-Type: multipart/signed; protocol="application/x-pkcs7-signature"; micalg="sha-256"; boundary="--SIGNED-INSTALLER"'; echo; echo; echo '----SIGNED-INSTALLER'; cat Dynatrace-OneAgent-Linux-arm.sh ) | openssl cms -verify -CAfile dt-root.cert.pem > /dev/null
This command validates the downloaded installer before you run it.
Image Alt Text:Dynatrace UI showing generated OneAgent installer commandDynatrace OneAgent installation command
Install OneAgent as the privileged user
Copy the command under Install OneAgent as the privileged user from your Dynatrace dashboard and prepend sudo to run the install.
sudo /bin/sh Dynatrace-OneAgent-Linux-arm.sh --set-monitoring-mode=fullstack --set-app-log-content-access=true
        Starting Dynatrace OneAgent installer...
Installing OneAgent...
Setting agent configuration...
Installation finished successfully.
The installer performs several tasks automatically:
  • Downloads monitoring components
  • Configures kernel instrumentation
  • Installs the OneAgent system service
  • Registers the host with your Dynatrace environment
Verify OneAgent service
Check that the Dynatrace monitoring service is running.
sudo systemctl status oneagent
        ● oneagent.service - Dynatrace OneAgent
  Loaded: loaded (/etc/systemd/system/oneagent.service; enabled; preset: enabled)
  Active: active (running)
This confirms the monitoring agent started successfully.
Verify Dynatrace processes
You can also check the OneAgent processes from the terminal.
ps aux | grep oneagent
        dtuser     17754  0.0  0.0 307872  4388 ?        Ssl  05:48   0:00 /opt/dynatrace/oneagent/agent/lib64/oneagentwatchdog -bg -config=/opt/dynatrace/oneagent/agent/conf/watchdog.conf
dtuser     17761  0.2  0.3 1183000 59136 ?       Sl   05:48   0:06 oneagentos -Dcom.compuware.apm.WatchDogTimeout=900 -watchdog.restart_file_location=/var/lib/dynatrace/oneagent/agent/watchdog/watchdog_restart_file -Dcom.compuware.apm.WatchDogPipe=/var/lib/dynatrace/oneagent/agent/watchdog/oneagentos_pipe_17754
dtuser     17793  0.0  0.2 689184 34408 ?        Sl   05:48   0:01 oneagentloganalytics -Dcom.compuware.apm.WatchDogTimeout=900 -Dcom.compuware.apm.WatchDogPipe=/var/lib/dynatrace/oneagent/agent/watchdog/oneagentloganalytics_pipe_17754
dtuser     17795  0.1  0.2 361936 42940 ?        Sl   05:48   0:04 oneagentnetwork -Dcom.compuware.apm.WatchDogTimeout=900 -Dcom.compuware.apm.WatchDogPipe=/var/lib/dynatrace/oneagent/agent/watchdog/oneagentnetwork_pipe_17754
dtuser     17883  0.0  0.0  28212  5340 ?        Sl   05:49   0:00 /opt/dynatrace/oneagent/agent/lib64/oneagentebpfdiscovery --log-dir /var/log/dynatrace/oneagent/os/ --log-no-stdout --log-level info
azureus+   23847  0.0  0.0   9988  2772 pts/0    S+   06:33   0:00 grep --color=auto oneagent
Confirm host detection in Dynatrace
Return to the Dynatrace web interface.
Navigate to:
Infrastructure & Operations
→ Hosts
You should see:
        Host name: <vm-name>
OS: Linux
Architecture: ARM64
Monitoring mode: Full Stack
Image Alt Text:Dynatrace hosts dashboard showing detected ARM64 virtual machineDynatrace host monitoring dashboard
Check automatic process discovery
Dynatrace automatically discovers running applications and services.
View them under:
Hosts → Processes
Dynatrace identifies services such as:
  • system processes
  • web servers
  • databases
  • container runtimes
Image Alt Text:Dynatrace process monitoring dashboard showing automatically discovered servicesDynatrace process discovery view
Dynatrace OneAgent is now monitoring your Azure Cobalt 100 virtual machine. The agent runs as a system service, automatically discovers processes, and securely transmits monitoring data to your Dynatrace environment.
Next, you’ll install Dynatrace ActiveGate to enable secure data routing, Kubernetes monitoring, and extension support.
