Configure Azure firewall for Dynatrace ActiveGate
To allow external traffic on port 9999 for Dynatrace ActiveGate running on an Azure virtual machine, open the port in the Network Security Group (NSG) attached to the virtual machine’s network interface or subnet.
Note
For more information about Azure setup, see Getting started with Microsoft Azure Platform .
Create a firewall rule in Azure
To expose the TCP port 9999, create a firewall rule.
Navigate to the Azure Portal , go to Virtual Machines, and select your virtual machine.
Image Alt Text:Azure Portal showing Virtual Machines list alt-txtVirtual Machines
In the left menu, select Networking and in the Networking select Network settings that’s associated with the virtual machine’s network interface.
Image Alt Text:Azure Portal showing Network settings with security group configuration alt-txtNetwork settings
Navigate to Create port rule, and select Inbound port rule.
Image Alt Text:Azure Portal showing Create port rule dropdown menu alt-txtCreate rule
Configure the inbound security rule with the following settings:
  • Source: Any
  • Source port ranges: *
  • Destination: Any
  • Destination port ranges: 9999
  • Protocol: TCP
  • Action: Allow
  • Name: allow-tcp-9999
After filling in the details, select Add to save the rule.
Image Alt Text:Azure Portal showing inbound security rule form with port 9999 configuration alt-txtNetwork settings
The network firewall rule is now created, allowing Dynatrace ActiveGate to communicate over port 9999.
You’ve configured the Azure Network Security Group to allow incoming traffic on port 9999. This firewall rule enables secure communication between your virtual machine and the Dynatrace platform when you install ActiveGate.
Next, you’ll install Dynatrace OneAgent on your Azure Cobalt 100 virtual machine to begin monitoring system resources and processes.
