Dynatrace ActiveGate acts as a secure gateway between monitored environments and the Dynatrace SaaS platform.
It improves scalability, enables Kubernetes monitoring, and routes monitoring traffic efficiently.
In this guide, you’ll install Dynatrace ActiveGate on an Azure Ubuntu 24.04 LTS Arm64 virtual machine running on Azure Cobalt 100 processors.
After installation completes, ActiveGate:
aarch64) architectureActiveGate is commonly installed on a host that already has Dynatrace OneAgent installed.
This allows ActiveGate to securely route monitoring traffic from OneAgent to the Dynatrace environment.
Verify that OneAgent is running:
sudo systemctl status oneagent
If OneAgent isn’t installed, install it first using the previous guide.
Open your Dynatrace environment in a browser.
https://<ENVIRONMENT-ID>.live.dynatrace.com
Example:
https://qzo722404.live.dynatrace.com
This is your Dynatrace SaaS environment URL.
From the Dynatrace main dashboard:
Dynatrace ActiveGate not yet installed
Dynatrace generates an installation command specifically for your environment.
On the installer configuration page:
Dynatrace ActiveGate installation configuration
This ensures that the installer downloads the Arm64-compatible ActiveGate binaries.
Dynatrace generates a command similar to the following:
Download ActiveGate:
wget -O Dynatrace-ActiveGate-Linux-arm.sh \
"https://<ENVIRONMENT-ID>.live.dynatrace.com/api/v1/deployment/installer/gateway/unix/latest?arch=arm" \
--header="Authorization: Api-Token <API_TOKEN>"
Example:
"https://qzo72404.live.dynatrace.com/api/v1/deployment/installer/gateway/unix/latest?arch=arm" \
--header="Authorization: Api-Token DT_API_TOKEN"
Verify signature:
wget https://ca.dynatrace.com/dt-root.cert.pem
( echo 'Content-Type: multipart/signed; protocol="application/x-pkcs7-signature"; micalg="sha-256"; boundary="--SIGNED-INSTALLER"'; echo; echo; echo '----SIGNED-INSTALLER'; cat Dynatrace-ActiveGate-Linux-arm.sh ) | openssl cms -verify -CAfile dt-root.cert.pem > /dev/null
Dynatrace ActiveGate installer command
Install ActiveGate as the privileged user:
Copy the command under “Install ActiveGate as the privileged user” from your dashboard and prepend “sudo " to it to launch the install:
sudo /bin/bash Dynatrace-ActiveGate-Linux-arm.sh
The installer automatically performs the following tasks:
The output is similar to:
2026-03-12 05:59:21 UTC Starting Dynatrace ActiveGate AutoUpdater...
2026-03-12 05:59:21 UTC Checking if Dynatrace ActiveGate AutoUpdater is running ...
2026-03-12 05:59:21 UTC Dynatrace ActiveGate AutoUpdater is running.
2026-03-12 05:59:21 UTC Cleaning autobackup...
2026-03-12 05:59:21 UTC Removing old installation log files...
2026-03-12 05:59:21 UTC --------------------------------------------------------------
2026-03-12 05:59:21 UTC Installation finished successfully.
Check that the ActiveGate service is running.
sudo systemctl status dynatracegateway
● dynatracegateway.service - Dynatrace ActiveGate service
Loaded: loaded (/etc/systemd/system/dynatracegateway.service; enabled; preset: enabled)
Active: active (running) since Thu 2026-03-12 05:59:07 UTC; 1min 7s ago
Process: 20280 ExecStart=/opt/dynatrace/gateway/dynatracegateway start (code=exited, status=0/SUCCESS)
This confirms that ActiveGate started successfully.
ActiveGate communicates using port 9999.
Verify that the port is listening:
sudo ss -tulnp | grep 9999
tcp LISTEN 0 50 *:9999 *:* users:(("java",pid=20319,fd=403))
This confirms that ActiveGate is accepting incoming connections.
Open the Dynatrace web interface and navigate to:
Deployment Status → ActiveGates
You should see your ActiveGate instance listed with:
Dynatrace ActiveGate deployment status
Dynatrace ActiveGate details view
To validate that Dynatrace is collecting monitoring data correctly, deploy a simple web server on the virtual machine. Dynatrace OneAgent automatically detects and monitors the process.
Update the package index and install the Nginx web server.
sudo apt update
sudo apt install -y nginx
sudo systemctl status nginx
Dynatrace OneAgent automatically discovers running processes and services.
Return to the Dynatrace web interface and navigate to:
Infrastructure & Operations → Hosts
Select your monitored host and open:
Processes
You should see a process similar to:
nginxDynatrace automatically begins collecting metrics such as:
Dynatrace NGINX process monitoring dashboard
Your Azure Cobalt 100 virtual machine now has a complete Dynatrace monitoring stack. OneAgent monitors host resources and processes, while ActiveGate securely routes monitoring data to your Dynatrace environment through port 9999. The entire setup operates natively on Arm64 architecture, providing full observability for your applications and infrastructure.
