Open port
8080 to the internet as part of the VM setup. After starting the app, connect to the VM’s public IP on port 8080.The
gcc command produces a shared object named libmylib.so. This is the library the C# code will load.Call the function via
DllImport and check the application’s console output for Hello from the C library!. Seeing that line confirms that the native call executed.Use .NET’s
AnyCPU configuration. It provides an architecture-agnostic managed build that runs on both architectures..NET 8 is the current Long-Term Support (LTS) version until Nov 2026, .NET 9 is the Short-Term Support (STS) version until Nov 2026, and .NET 10 is the next LTS in preview. .NET versions 3.1, 5, 6, and 7 have reached End-of-Life (EOL).
