In this section, you’ll integrate a simple C shared library into your .NET OrchardCore application, by doing the following:
.so)DllImportThis allows you to reuse existing C code and improve performance by accessing native functionality.
Create a file named mylib.c with the following:
#include <stdio.h>
void greet() {
printf("Hello from the C library!\n");
Compile the C file into a shared library:
gcc -shared -o libmylib.so -fPIC mylib.c
This creates a shared object file named libmylib.so which your .NET application can call at runtime.
Now that you have a shared library, you can use it in your .NET application.
In your OrchardCore application, create a new class file named NativeMethods.cs:
using System;
using System.Runtime.InteropServices;
public static class NativeMethods
[DllImport("mylib", EntryPoint = "greet")]
public static extern void Greet();
On Linux, the DllImport("mylib") attribute resolves to libmylib.so. On Windows, the runtime would look for mylib.dll, and on macOS, libmylib.dylib.
Call the Greet method from your application. For example, you can add the following code to your main program Program.cs as shown:
using OrchardCore.Logging;
var builder = WebApplication.CreateBuilder(args);
builder.Host.UseNLogHost();
builder.Services
.AddOrchardCms()
// // Orchard Specific Pipeline
// .ConfigureServices( services => {
// .Configure( (app, routes, services) => {
var app = builder.Build();
Console.WriteLine("Calling native greet..."); // NEW INTEROP LINE
NativeMethods.Greet(); // NEW INTEROP LINE
if (!app.Environment.IsDevelopment())
app.UseExceptionHandler("/Error");
// The default HSTS value is 30 days. You may want to change this for production scenarios, see https://aka.ms/aspnetcore-hsts.
app.UseHsts();
app.UseHttpsRedirection();
app.UseStaticFiles();
app.UseOrchardCore();
app.Run();
Ensure that dotnet can find your shared library:
export LD_LIBRARY_PATH=$(pwd):$LD_LIBRARY_PATH
When you run dotnet run, you’ll see the following output:
If you are compiling for Arm directly on Azure Cobalt, the compiler understands the default processor optimizations it should use, and you can compile in the same way as above.
However, if you are cross-compiling in your build pipeline, you should specify -mcpu=neoverse-n2 -O3 when running the cross-compiler:
aarch64-linux-gnu-gcc -mcpu=neoverse-n2 -O3 -shared -o libmylib.so -fPIC mylib.c
The -mcpu=neoverse-n2 flag specifies the Cobalt architecture, and -O3 ensures that maximum optimizations are completed (including SIMD optimizations).
In the next section, you’ll make your native interop cross-platform by using the AnyCPU feature and runtime dispatch strategies.
