In this section, you’ll build and run a basic OrchardCore CMS application, which is a popular Linux-based .NET workload. OrchardCore is a modular and multi-tenant application framework built with ASP.NET Core, that’s commonly used to create content-driven websites.
First, launch an Azure Cobalt 100 instance (Arm-based VM) running Ubuntu 24.04, and open port 8080 to the internet.
For setup instructions, see the Create an Azure Cobalt 100 VM Learning Path.
Next, install .NET SDK:
wget https://packages.microsoft.com/config/ubuntu/24.04/packages-microsoft-prod.deb
sudo dpkg -i packages-microsoft-prod.deb
sudo apt-get update
sudo apt-get install -y dotnet-sdk-8.0
Verify the installation:
dotnet --version
You should then see output similar to:
8.0.117
Install gcc for compiling your application:
sudo apt install gcc g++ build-essential -y
Install the OrchardCore templates:
dotnet new install OrchardCore.ProjectTemplates::2.1.7
This command installs the OrchardCore project templates you’ll use to create a new OrchardCore application.
Expected output:
Success: OrchardCore.ProjectTemplates::2.1.7 installed the following templates:
Template Name Short Name Language Tags
Orchard Core Cms Module ocmodulecms [C#] Web/Orchard Core/CMS
Orchard Core Cms Web App occms [C#] Web/Orchard Core/CMS
Orchard Core Mvc Module ocmodulemvc [C#] Web/Orchard Core/Mvc
Orchard Core Mvc Web App ocmvc [C#] Web/Orchard Core/Mvc
Orchard Core Theme octheme [C#] Web/Orchard Core/CMS
First, create a new project using the dotnet CLI to create a new OrchardCore application:
dotnet new occms -n MyOrchardCoreApp
This command creates a new OrchardCore CMS application in a directory named MyOrchardCoreApp.
Now navigate to the project directory:
cd MyOrchardCoreApp
Build the application:
dotnet build
The output should look like:
MSBuild version 17.8.27+3ab07f0cf for .NET
Determining projects to restore...
Restored /home/azureuser/MyOrchardCoreApp/MyOrchardCoreApp.csproj (in 28.95 sec).
MyOrchardCoreApp -> /home/azureuser/MyOrchardCoreApp/bin/Debug/net8.0/MyOrchardCoreApp.dll
Copying translation files: MyOrchardCoreApp
Build succeeded.
0 Warning(s)
0 Error(s)
Time Elapsed 00:00:38.05
Run the application:
dotnet run --urls http://0.0.0.0:8080
Access the application:
In your browser, navigate to http://[instance IP]:8080 to see your OrchardCore application in action.
Replace [instance IP] with your VM’s public IP address. You can find it in the Azure portal under the Networking tab of your virtual machine.
Configure the application:
You have successfully created and run a basic OrchardCore CMS application. In the next sections, you will learn how to integrate a C shared library into your .NET application and explore performance optimizations for Arm architecture.
