Explore related resources
Give feedback
AI-assisted
Close
How should I choose the Azure VM configuration for the baseline?
Provision an Azure Cobalt-based environment as described in the Azure Cobalt Learning Path and keep the toolchain and runtime configuration stable across runs. The flow was validated with Ubuntu 24.04 LTS in westus2 on an example size of Standard_D2ps_v6.
What should I record when pinning the nopCommerce source?
Check out the specified release tag and run git rev-parse --short=10 to capture the exact commit. Record the tag and short commit alongside the baseline results to avoid dependency drift.
How do I map direct and transitive dependencies before migration?
From the repository root, use rg -n "<PackageReference|<ProjectReference" src to identify direct references and the owning projects. Then generate an SBOM and review transitive packages to uncover native payloads that could affect Arm deployment.
Which containerization path should I start with?
Use the Dockerfile workflow as the default path for nopCommerce. Switch to .NET SDK publish when you want MSBuild-owned image metadata and have a repeatable plan for native packages, ensuring the SDK image matches Linux runtime dependencies and smoke-test results.
How do I know performance tuning changes took effect?
Stop the baseline process, set the runtime environment variables, and restart the application so the .NET runtime reads the new settings. Measure with fixed workloads and compare against the Arm endpoint baseline, keeping settings outside the code to switch profiles without rebuilding.
