Migrate nopCommerce to Arm on Microsoft Azure
Set up an Arm-based environment
Create a nopCommerce endpoint benchmark baseline on Arm
Generate an SBOM and run .NET dependency discovery before migration
Choose a containerization path for the nopCommerce application
Tune the performance of the .NET application on Azure
Use the Arm MCP Server to optimize .NET performance
Set up a Microsoft Azure virtual machine powered by Cobalt 100
Set up an Arm Azure environment first, then keep your toolchain and runtime configuration stable across all test runs. This creates a reliable Arm baseline for migration and tuning work.
Start with the Azure Cobalt Learning Path and complete VM provisioning.
The Learning Path was validated with Ubuntu 24.04 LTS on Azure Cobalt in westus2 (example VM size: Standard_D2ps_v6, 2 vCPUs).
Install tools on the Azure virtual machine
Install the toolchain on the Azure VM before building and testing.
The following commands install the Linux packages used throughout this Learning Path: source control, HTTP validation, JSON inspection, Python for the endpoint tester, package archive inspection, Docker, and the .NET 9 SDK from the Ubuntu backports feed:
sudo apt-get update -y
sudo apt-get install -y git curl jq python3 ripgrep unzip ca-certificates gnupg software-properties-common docker.io
sudo usermod -aG docker "$USER"
sudo add-apt-repository ppa:dotnet/backports -y
sudo apt-get install -y dotnet-sdk-9.0
The Docker group change applies to new login sessions. Sign out and sign back in before running Docker without sudo, or run newgrp docker in the current terminal before continuing.
Confirm architecture and tool versions before proceeding:
uname -m
dotnet --version
docker --version
On Azure Cobalt, the Linux machine architecture should be aarch64, and the .NET SDK should be a 9.0.x release.
The output is similar to:
aarch64
9.0.x
Docker version ...
If you’re upgrading from an older .NET version before migrating to Cobalt, use
GitHub Copilot modernization for .NET
to assess the project and guide the upgrade. In Visual Studio Code, open Copilot Chat and use @modernize-dotnet. In Visual Studio, use the Modernize action from Solution Explorer.
Enable citext to satisfy PostgreSQL prerequisite
nopCommerce defaults to SQL Server, but you’ll use PostgreSQL for Arm validation. For PostgreSQL installs, you need citext before migration and installation. Without it, installer migrations fail with type "citext" does not exist (captured in local test artifacts).
Create PostgreSQL and enable citext before running the installer. The database runs in Docker on the VM so the nopCommerce app can connect to 127.0.0.1:5432 during the local validation phase.
Replace the password value before running the following commands:
export NOP_POSTGRES_PASSWORD='replace-with-a-strong-password'
# Start PostgreSQL for local validation.
docker run -d --name nop-postgres \
-e POSTGRES_USER=nop \
-e POSTGRES_PASSWORD="$NOP_POSTGRES_PASSWORD" \
-e POSTGRES_DB=nopcommerce \
-p 5432:5432 postgres:16
# Enable the extension required by nopCommerce migrations.
docker exec nop-postgres psql -U nop -d nopcommerce \
-c "CREATE EXTENSION IF NOT EXISTS citext;"
The docker exec command should print CREATE EXTENSION. If it prints NOTICE: extension "citext" already exists, skipping, the database is already prepared and you can continue.
You’ve set up an Arm-based environment by creating a Microsoft Azure VM powered by Cobalt 100 with Docker, .NET 9, and PostgreSQL ready for nopCommerce validation.
Next, you’ll create a reproducible baseline to use for benchmarking.
