Open the project in VS Code
Open the cloned docker-blog-arm-migration directory in VS Code:
cd docker-blog-arm-migration
code .
Make sure the MCP_DOCKER server is running in VS Code (use Extensions > MCP_DOCKER > Start Server if needed).
This allows GitHub Copilot to invoke the configured MCP servers through the MCP Gateway.
Provide migration instructions to GitHub Copilot
Open GitHub Copilot Chat in VS Code and paste the following prompt:
Your goal is to migrate this codebase from x86 to Arm64. Use the Arm MCP
Server tools to help you with this migration.
Steps to follow:
1. Check all Dockerfiles - use check_image and/or skopeo tools to verify
   Arm compatibility, changing the base image if necessary
2. Scan the codebase - run migrate_ease_scan with the appropriate language
   scanner and apply the suggested changes
3. Use knowledge_base_search when you need Arm architecture guidance or
   intrinsic equivalents
4. Update compiler flags and dependencies for Arm64 compatibility
5. Create a pull request with all changes using GitHub MCP Server
Important notes:
- Your current working directory is mapped to /workspace on the MCP server
- NEON lane indices must be compile-time constants, not variables
- If unsure about Arm equivalents, use knowledge_base_search to find docs
- Be sure to find out from the user or system what the target machine is,
  and use the appropriate intrinsics. For instance, if neoverse (Graviton,
  Axion, Cobalt) is targeted, use the latest SVE2 (or SVE for older neoverse).
After completing the migration:
- Create a pull request with a detailed description of changes
- Include performance predictions and cost savings in the PR description
- List all tools used and validation steps needed
This prompt instructs Copilot to use structured MCP tools rather than relying purely on generated suggestions.
Observe the migration workflow
Copilot now orchestrates the migration using the configured MCP servers. The workflow typically proceeds in several phases.
Phase 1: Container Image analysis
Copilot invokes check_image or skopeo from the Arm MCP Server:
Checking centos:6 for arm64 support...
The tool reports that centos:6 has no linux/arm64 build available. Copilot proposes replacing the base image with a modern multi-architecture alternative. This step ensures the container can build and run on Arm hardware before addressing source-level changes.
Phase 2: Source Code scanning
Copilot runs the migrate_ease_scan tool with the C++ scanner:
Running migrate_ease_scan with scanner: cpp
The scan detects:
  • AVX2 intrinsics (_mm256_* functions) in matrix_operations.cpp.
  • The -mavx2 compiler flag in the Dockerfile.
  • The x86-specific header <immintrin.h>.
Each finding includes file locations and recommended actions. This structured scan avoids manually searching through the codebase.
Phase 3: Knowledge base lookup and refactoring code
For each x86 intrinsic found, Copilot queries the Arm MCP Server knowledge base:
Searching knowledge base for: AVX2 to NEON intrinsic conversion
The Arm MCP knowledge base provides documented guidance on intrinsic mapping and architecture considerations. Example mappings:
x86 AVX2 IntrinsicArm Neon Equivalent
_mm256_setzero_pd()Two vdupq_n_f64(0.0) operations
_mm256_loadu_pd()Two vld1q_f64() loads
_mm256_add_pd()Two vaddq_f64() operations
_mm256_mul_pd()Two vmulq_f64() operations
Because AVX2 operates on 256-bit vectors (four doubles) and Neon operates on 128-bit vectors (two doubles), Copilot adjusts:
  • Loop stride
  • Accumulation logic
  • Horizontal reduction pattern
The refactoring typically includes:
  • Guarding architecture-specific code with #ifdef aarch64
  • Replacing <immintrin.h> with <arm_neon.h> where appropriate
  • Updating compiler flags (for example replacing -mavx2)
  • Selecting an Arm-compatible base image such as ubuntu:22.04
  • Supporting multi-architecture builds using TARGETARCH
All proposed changes should be reviewed before merging.
Phase 4: Pull request creation
Once modifications are complete, Copilot invokes the GitHub MCP Server to:
  • Create a branch
  • Commit changes
  • Open a pull request
The PR typically includes:
  • Updated Dockerfile
  • Refactored source files
  • A description of the changes
  • A summary of MCP tools used
  • Suggested validation steps for Arm hardware
You can see an example PR at github.com/JoeStech/docker-blog-arm-migration/pull/1 .
Summary of changes
After migration, you should see:
Dockerfile updates:
  • Replaced centos:6 with ubuntu:22.04
  • Added TARGETARCH for multi-architecture builds
  • Changed -mavx2 to -march=armv8-a+simd for Arm builds
Source code updates:
  • Added #ifdef __aarch64__ architecture guards
  • Replaced all _mm256_* AVX2 intrinsics with Neon equivalents (vld1q_f64, vaddq_f64, vmulq_f64)
  • Adjusted loop strides from 4 (AVX2) to 2 (Neon)
  • Rewrote horizontal reduction using Neon pair-wise addition
You have:
  • Provided migration instructions to GitHub Copilot
  • Observed the AI-driven workflow using MCP server tools
  • Reviewed the automated changes: container image updates, intrinsic mapping, and compiler flag adjustments
  • Seen how the GitHub MCP Server creates a pull request with all migration changes
Next, you’ll build and validate the migrated application on Arm64 hardware.
