Deploy Django REST API on GKE Axion with Cloud SQL and Redis
This section shows you how to deploy a Django REST API on Google Kubernetes Engine (GKE) using Axion (Arm64) nodes.
The application integrates with:
  • Cloud SQL (PostgreSQL – private IP)
  • Memorystore (Redis)
  • Artifact Registry
  • Kubernetes LoadBalancer
Performance is validated using throughput and p95 latency, allowing you to evaluate how an Arm-based Kubernetes platform behaves under real application load.
Target architecture
        Client
| HTTP (LoadBalancer)
v
GKE (Axion Arm64)
|-- Django REST API (Gunicorn)
|---> Cloud SQL (PostgreSQL – private IP)
|---> Memorystore (Redis)
This architecture represents a production-grade microservice deployment where compute runs on Arm, while data services are provided through fully managed GCP offerings over private networking.
Set up the infrastructure
The following sections guide you through provisioning all required GCP services.
Enable the SUSE Containers module
Enable the SUSE Containers Module to ensure that Docker and container-related tools are fully supported.
sudo SUSEConnect -p sle-module-containers/15.5/arm64
sudo SUSEConnect --list-extensions | grep Containers
The output shows the Containers module as Activated.
Install Docker
Docker is required to run KinD and the Kubernetes control plane components. Install Docker, start the service, and add your user to the docker group:
sudo zypper refresh
sudo zypper install -y docker
sudo systemctl enable --now docker
sudo usermod -aG docker $USER
exit
Exit the current shell and reconnect to the virtual machine so that the group membership change takes effect.
Verify that Docker is running:
docker ps
The output is similar to:
        CONTAINER ID   IMAGE     COMMAND   CREATED   STATUS    PORTS     NAMES
Install kubectl (Kubernetes CLI)
Install the kubectl command-line tool for interacting with Kubernetes clusters:
curl -LO https://dl.k8s.io/release/v1.30.1/bin/linux/arm64/kubectl
chmod +x kubectl
sudo mv kubectl /usr/local/bin/
Verify kubectl installation
Confirm that kubectl is installed and accessible from the command line:
kubectl version --client
        Client Version: v1.30.1
Kustomize Version: v5.0.4-0.20230601165947-6ce0bf390ce3
Configure Google Cloud project
Retrieve your project ID:
gcloud projects list
        PROJECT_ID              NAME             PROJECT_NUMBER
arm-lp-test             arm-lp-test      834184475014
Note the PROJECT_ID for use in the next step.
Set the active project
Ensure the correct GCP project is selected:
gcloud config set project <YOUR_PROJECT_ID>
Replace <YOUR_PROJECT_ID> with your actual project ID from the previous step.
Install the auth plugin for gcloud
gcloud components install gke-gcloud-auth-plugin
Create Artifact Registry
Artifact Registry is used to store and distribute the Docker images for your Django application. This ensures that all Kubernetes nodes pull trusted, versioned images from a private Google-managed repository.
gcloud artifacts repositories create django-arm \
  --repository-format=docker \
  --location=us-central1
sudo chmod 777 /etc/containers
gcloud auth configure-docker us-central1-docker.pkg.dev
Artifact Registry is configured to store your container images.
Create the GKE control plane
Create the Kubernetes control plane that manages scheduling, networking, and workloads. Initially create it with a small node pool so the cluster can bootstrap.
gcloud container clusters create django-axion-cluster \
  --zone us-central1-a \
  --machine-type c4a-standard-4 \
  --num-nodes 1 \
  --enable-ip-alias
The GKE cluster is running.
Configure kubectl access to GKE
Fetch cluster credentials:
gcloud container clusters get-credentials django-axion-cluster \
Verify cluster access
Confirm Kubernetes access:
kubectl get nodes
        NAME                                                  STATUS   ROLES    AGE   VERSION
gke-django-axion-cluster-default-pool-156e91c3-wdsb   Ready    <none>   34m   v1.33.5-gke.2072000
All nodes are in Ready state and the Kubernetes control plane is accessible.
Taint the cluster nodes for arm64 support
Taint the nodes to ensure proper scheduling on arm64 VMs. For each node starting with gke, run the following taint command.
Note Note the required “-” at the end.
For example using the node IDs in the output above:
kubectl taint nodes gke-django-axion-cluster-default-pool-156e91c3-wdsb kubernetes.io/arch=arm64:NoSchedule-
Replace the node names with your actual node names from the previous command output.
Add Axion (Arm64) node po
Axion (Arm64) nodes provide high performance per watt and cost-efficient compute. This pool runs all Django application workloads.
gcloud container node-pools create axion-pool \
  --cluster django-axion-cluster \
  --num-nodes 2
Delete the x86 pool:
gcloud container node-pools delete default-pool \
The Kubernetes cluster runs exclusively on Axion Arm64 nodes.
Create Cloud SQL (PostgreSQL with private IP)
Cloud SQL provides a fully managed PostgreSQL database. Private IP ensures traffic stays inside Google’s private network, improving security and performance.
Enable private services access:
gcloud services enable servicenetworking.googleapis.com
gcloud compute addresses create google-managed-services-default \
  --global --purpose=VPC_PEERING --prefix-length=16 --network=default
gcloud services vpc-peerings connect \
  --service=servicenetworking.googleapis.com \
  --ranges=google-managed-services-default \
  --network=default
Create the PostgreSQL instance:
gcloud sql instances create django-postgres \
  --database-version=POSTGRES_15 \
  --cpu=2 \
  --memory=8GB \
  --region=us-central1 \
  --network=default \
  --no-assign-ip
Create the database and user:
gcloud sql databases create django_db --instance=django-postgres
gcloud sql users create django_user --instance=django-postgres --password=password
Get the IP address:
gcloud sql instances describe django-postgres \
  --format="value(ipAddresses[0].ipAddress)"
Save this IP address as CLOUDSQL_IP for later use.
Create Memorystore (Redis)
Redis is used for caching, sessions, and background job coordination. Memorystore provides a fully managed Redis service that scales and stays highly available.
gcloud redis instances create django-redis \
  --size=1 \
  --tier=STANDARD
gcloud redis instances describe django-redis \
  --format="value(host)"
Save this IP address as REDIS_IP for later use.
In this section, you created the complete infrastructure for your Django deployment:
  • Axion-based GKE cluster with Arm64 node pools
  • Private Cloud SQL PostgreSQL instance
  • Memorystore Redis instance
  • Artifact Registry for container images
Next, you’ll build a Django REST API that connects to these services, then containerize and deploy it to your Axion GKE cluster.
