Install Django and dependencies
After connecting to your SUSE Linux Enterprise Server (SLES) VM using SSH, you’ll install the Google Cloud CLI, update your system, install Python 3.11, and set up a virtual environment for your Django project.
Prepare the system
Update the system packages and install dependencies:
sudo zypper refresh
sudo zypper update -y
sudo zypper install -y curl git tar gzip
Install Python 3.11
Install Python 3.11:
sudo zypper install -y python311
which python3.11
Verify that Python and pip are installed correctly:
python3.11 --version
pip3.11 --version
The output is similar to:
        Python 3.11.10
pip 22.3.1 from /usr/lib/python3.11/site-packages/pip (python 3.11)
Install Google Cloud CLI (gcloud)
The Google Cloud CLI is required to authenticate with GCP and allow your Django application VM to interact with Google Cloud services such as GKE, Cloud SQL, Artifact Registry, Memorystore, and to build, deploy, and operate the Django platform.
Download and extract the Google Cloud SDK:
wget https://dl.google.com/dl/cloudsdk/channels/rapid/downloads/google-cloud-sdk-460.0.0-linux-arm.tar.gz
tar -xvf google-cloud-sdk-460.0.0-linux-arm.tar.gz
Install gcloud:
./google-cloud-sdk/install.sh
After installation completes, exit and reconnect to apply the PATH changes:
exit
Initialize gcloud
Authenticate and configure the Google Cloud CLI:
gcloud init
During initialization, select Login with a new account. You’ll be prompted to authenticate using your browser and receive an auth code to copy back. Select the project you want to use and choose default settings when unsure.
Verify authentication
gcloud auth list
        Credentialed Accounts
ACTIVE  ACCOUNT
*       <PROJECT_NUMBER>-compute@developer.gserviceaccount.com
Create a project directory and virtual environment
Create a dedicated directory for your Django project and set up a Python virtual environment to isolate your project’s dependencies:
mkdir ~/myproject && cd ~/myproject
python3.11 -m venv venv
source venv/bin/activate
The python3.11 -m venv venv command creates an isolated Python environment named venv inside your project folder. Running source venv/bin/activate activates this environment.
Once activated, your command prompt displays (venv) at the beginning, indicating that you’re working inside an isolated Python environment.
Upgrade pip and install Django
With your virtual environment active, upgrade pip to the latest version:
python3 -m pip install --upgrade pip
Now install Django and additional useful packages for web development:
python3 -m pip install django gunicorn
This installs:
  • Django - the web framework for building your application
  • Gunicorn - a production-ready WSGI (Web Server Gateway Interface) server for running Django applications
Verify that Django is installed correctly:
django-admin --version
        5.2.10
In this section, you installed:
  • Google Cloud CLI for GCP service management
  • Python 3.11 with a virtual environment
  • Django and Gunicorn for web application development
Next, you’ll verify Django is working by creating a basic project and running the development server.
