Open port 8000 for your Django application
Before you can access your Django development server from your browser, you need to configure Google Cloud’s firewall to allow inbound traffic on port 8000. This section walks you through creating a firewall rule that permits HTTP requests to reach your VM.
Note
For support on GCP setup, see the Learning Path Getting started with Google Cloud Platform .
Create a firewall rule in Google Cloud Console
Navigate to the Google Cloud Console and create a new firewall rule:
  • Go to the Google Cloud Console.
  • Select VPC network > Firewall.
  • Select Create firewall rule.
Image Alt Text:Screenshot of the Google Cloud Console showing the Firewall section. The Create firewall rule button is prominently displayed at the top of the pageGoogle Cloud Console Firewall page
Configure the firewall rule
Fill in the rule details to allow traffic on port 8000:
  • Set Name to allow-tcp-8000.
  • Select your network (the default is default; your organization may use a different network).
  • Set Direction of traffic to Ingress.
  • Set Action on match to Allow.
  • Set Targets to Specified target tags.
  • Enter allow-tcp-8000 in the Target tags field.
  • Set Source IPv4 ranges to 0.0.0.0/0 (allows traffic from any IP address; restrict this in production).
Image Alt Text:Screenshot showing the firewall rule configuration form. The Name field shows allow-tcp-8000, Direction is set to Ingress, and Targets is set to Specified target tagsFirewall rule configuration
Specify the port and protocol
Configure the protocol and port settings:
  • Under Protocols and ports, select Specified protocols and ports.
  • Check the TCP checkbox.
  • Enter 8000 in the Ports field.
  • Click Create.
Image Alt Text:Screenshot of the Protocols and ports section. The TCP checkbox is checked and port 8000 is entered in the Ports fieldSpecifying TCP port 8000
In this section, you configured firewall rules to allow external HTTP traffic on port 8000, making your Django application accessible from the internet.
Next, you’ll provision a Google Axion C4A Arm VM to host your Django application.
