Get started with Django on Google Axion C4A
Configure firewall rules for Django on Google Cloud
Create a Google Axion C4A Arm virtual machine on GCP
Install Django on your Arm-based VM
Verify Django installation and run the development server
Deploy Django on GKE Axion with managed data services
Build a Django REST API with PostgreSQL and Redis
Containerize and deploy Django on Axion GKE
Benchmark Django application performance on Arm
This section guides you through benchmarking your Django web application using Gunicorn as a production-like WSGI server and ApacheBench (ab) for load testing. You’ll measure throughput (requests per second) and latency (response time) to evaluate your Django app’s performance on an Arm-based Google Cloud C4A VM.
To begin, if your Django development server is still running, stop it using Ctrl + C.
Install ApacheBench to measure your application’s performance under load.
sudo zypper install -y apache2-utils
Verify the installation:
ab -V
You should see the ApacheBench version information displayed.
ApacheBench (ab) is a command-line tool that simulates multiple HTTP requests to measure web server performance. Install it using the following:
Confirm ApacheBench is correctly installed and available.
ab -V
The output displays the ApacheBench version.
Before benchmarking your Django application, you need to install Gunicorn, a production-grade WSGI HTTP server. Gunicorn provides better performance characteristics than Django’s development server and more accurately represents real-world deployment scenarios.
python3 -m pip install django gunicorn
This installs Django and Gunicorn. Gunicorn is a production-grade WSGI HTTP server that handles multiple requests at the same time. Unlike Django’s built-in development server, Gunicorn uses multiple workers to process requests efficiently, which gives you more accurate performance measurements.
Your Django application runs with Gunicorn inside GKE. The Gunicorn server is deployed inside your Kubernetes Pods and exposed through a Kubernetes Service and LoadBalancer. You run the benchmark against the external IP of the GKE service.
Use ApacheBench to test your Django server with simulated traffic:
ab -n 5000 -c 100 http://<external_IP_of_the_GKE_service>/healthz/
This command sends 5000 requests with 100 concurrent connections to your Django REST endpoint.
Parameters explained:
-n 5000: total number of requests to send-c 100: number of concurrent requestshttp://<external_IP_of_the_GKE_service>/healthz/: your Django health check endpointReplace <external_IP_of_the_GKE_service> with your actual GKE LoadBalancer IP address.
The benchmark runs for a few seconds and displays results similar to:
Server Software: gunicorn
Server Hostname: 34.132.110.81
Server Port: 80
Document Path: /healthz/
Document Length: 15 bytes
Concurrency Level: 100
Time taken for tests: 0.357 seconds
Complete requests: 5000
Failed requests: 0
Total transferred: 1650000 bytes
HTML transferred: 75000 bytes
Requests per second: 14001.88 [#/sec] (mean)
Time per request: 7.142 [ms] (mean)
Time per request: 0.071 [ms] (mean, across all concurrent requests)
Transfer rate: 4512.32 [Kbytes/sec] received
Connection Times (ms)
min mean[+/-sd] median max
Connect: 0 0 0.2 0 2
Processing: 1 6 4.7 6 32
Waiting: 0 6 4.7 6 32
Total: 1 7 4.8 6 34
Percentage of the requests served within a certain time (ms)
50% 6
66% 9
75% 10
80% 11
90% 11
95% 11
98% 16
99% 28
100% 34 (longest request)
The ApacheBench output provides key performance metrics for evaluating your Django application on Google Axion (Arm64) GKE:
Your benchmark captures three foundational indicators of request handling capacity:
Your Django application’s performance under load is measured by three critical metrics:
The benchmark captures how efficiently your application transfers data across the network stack:
The timing breakdown section provides detailed insight into how your application spends time processing each request:
These metrics establish a real production-grade performance baseline for your Django REST API running on GKE Axion (Arm64) with Gunicorn, Cloud SQL, and Redis.
The table below summarizes the key performance indicators from your real benchmark run on the Axion Arm64 GKE cluster.
Results from the run on the Axion (C4A) Arm64 GKE nodes:
| Parameter | Description | Value |
| Server Software | web server used for serving Django | gunicorn |
| Server Hostname | external LoadBalancer IP | 34.132.110.81 |
| Server Port | port number for benchmark | 80 |
| Document Path | endpoint used for testing | /healthz/ |
| Document Length | size of each response | 15 bytes |
| Concurrency Level | number of concurrent requests | 100 |
| Time Taken for Tests | total time to complete all requests | 0.357 seconds |
| Complete Requests | total number of successful requests | 5000 |
| Failed Requests | number of failed requests | 0 |
| Total Transferred | total bytes transferred (including headers) | 1,650,000 bytes |
| HTML Transferred | total response body bytes | 75,000 bytes |
| Requests per Second (mean) | throughput - higher is better | 14,001.88 req/sec |
| Time per Request (mean) | average time for each request | 7.142 ms |
| Time per Request (across all concurrent requests) | average latency considering concurrency | 0.071 ms |
| Transfer Rate | network throughput rate | 4512.32 KB/sec |
| p50 (Median Latency) | 50% of requests completed within | 6 ms |
| p90 Latency | 90% of requests completed within | 11 ms |
| p95 Latency | 95% of requests completed within | 11 ms |
| p99 Latency | 99% of requests completed within | 28 ms |
| Max Latency | longest request observed | 34 ms |
The benchmark results demonstrate the strength of running Django on Google Axion (Arm64) GKE:
In this section, you:
Your Django application is now proven to handle high-concurrency traffic efficiently on Arm-based infrastructure. You’ve established a performance baseline that demonstrates the scalability and reliability of running Django on Google Cloud’s Axion processors with GKE, Cloud SQL, and Redis.
You’re ready to optimize further, scale your deployment, or integrate additional services into your cloud-native Django architecture.
