Verify Django installation
In this section, you’ll confirm that Django is installed correctly and can serve web requests on your Google Cloud C4A VM. You’ll create a Django project, run the development server, and access it from your browser.
Run the following command to create a new Django project named myproject:
django-admin startproject myproject
cd myproject
This generates the following directory structure:
myproject/
├── manage.py
└── myproject/
    ├── settings.py
    ├── urls.py
    ├── asgi.py
    └── wsgi.py
The manage.py file is Django’s command-line utility for project management. The inner myproject/ folder contains your project’s core settings and URL configuration.
Run initial database migrations
Set up your project’s database by running migrations, which create the required tables for Django’s built-in apps:
python3 manage.py migrate
The output shows all migrations applied successfully (marked “OK”).
Configure ALLOWED_HOSTS for external access
Before starting the Django development server, you must configure your ALLOWED_HOSTS setting to allow access from your VM’s external IP. This ensures that Django accepts HTTP requests from outside localhost (for example, when testing in a browser from another machine).
Navigate to your project settings directory:
cd ~/myproject/myproject/
Open settings.py using a text editor:
edit myproject/settings.py
Locate the ALLOWED_HOSTS line inside the file:
ALLOWED_HOSTS = []
Update it to allow your VM’s external IP address:
To make your Django app accessible from your VM’s external IP address, update it to:
ALLOWED_HOSTS = ['*']
Note
For development and testing only, you can use ALLOWED_HOSTS = ['*'] to allow all hosts. However, for production deployments, always specify explicit domain names or IP addresses such as ALLOWED_HOSTS = ['your-external-ip', 'your-domain.com'].
Now that you’ve configured ALLOWED_HOSTS, start the development server:
python3 manage.py runserver 0.0.0.0:8000
This starts the Django development server on port 8000, listening on all network interfaces.
Access Django in your browser
Open a web browser on your local machine and navigate to:
http://<YOUR_VM_EXTERNAL_IP>:8000
Replace <YOUR_VM_EXTERNAL_IP> with the public IP address of your GCP VM.
You should see the Django welcome page with the message “The install worked successfully!”:
Image Alt Text:Screenshot of the Django welcome page displayed in a web browser. The page features a large heading stating The install worked successfully followed by a subheading congratulating the user on successfully installing Django. Below are instructions for the next steps, including editing the settings file and reading the Django documentation. The page has a clean white background with blue highlights alt-txtDjango welcome page
Build a simple Django app with custom routing
This section demonstrates that Django’s application routing and view rendering work correctly by creating a simple app with a custom view.
Stop the server
Press Ctrl + C in your terminal to stop the Django development server.
Create a new Django app
Within your Django project directory, create a new app named hello:
python3 manage.py startapp hello
This generates the following directory structure with files for views, models, configuration, and more:
        hello/
├── admin.py
├── apps.py
├── models.py
├── tests.py
├── views.py
└── urls.py
Define a view function
Edit hello/views.py and replace the entire file with:
from django.http import HttpResponse
def home(request):
    return HttpResponse("<h1>Hello, Django on GCP SUSE ARM64!</h1>")
This simple view function returns a basic HTML message as an HTTP response.
Create URL configuration for your app
Create a new file hello/urls.py:
from django.urls import path
from . import views
urlpatterns = [
    path('', views.home, name='home'),
This maps the root URL path to your home() view function.
Include the app in your project’s main URLs
Edit myproject/urls.py to include the hello app’s URLs:
"""myproject URL Configuration
The `urlpatterns` list routes URLs to views. For more information please see:
    https://docs.djangoproject.com/en/3.2/topics/http/urls/
Examples:
Function views
    1. Add an import:  from my_app import views
    2. Add a URL to urlpatterns:  path('', views.home, name='home')
Class-based views
    1. Add an import:  from other_app.views import Home
    2. Add a URL to urlpatterns:  path('', Home.as_view(), name='home')
Including another URLconf
    1. Import the include() function: from django.urls import include, path
    2. Add a URL to urlpatterns:  path('blog/', include('blog.urls'))
from django.contrib import admin
from django.urls import path, include
urlpatterns = [
    path('admin/', admin.site.urls),
    path('', include('hello.urls')),
This tells Django to route the root path to your hello app.
Register the app in Django settings
Django needs to know about your new app. Edit myproject/settings.py and add 'hello' to the INSTALLED_APPS list:
INSTALLED_APPS = [
    'django.contrib.admin',
    'django.contrib.auth',
    'django.contrib.contenttypes',
    'django.contrib.sessions',
    'django.contrib.messages',
    'django.contrib.staticfiles',
    'hello',
Start the server again
Restart the Django development server:
Test your custom app
Open your browser and navigate to:
Your browser displays your custom message:
Image Alt Text:Screenshot of a web browser displaying a Django app with a large heading that reads Hello, Django on Arm, centered on a clean white background alt-txtDjango custom app
In this section, you:
  • Created a Django project and ran the development server
  • Built a custom Django app with routing and views
  • Verified that Django serves web requests successfully on your Arm VM
Next, you’ll set up the complete GKE infrastructure with Cloud SQL and Memorystore for production deployment.
