In this section, you configure the master node and verify communication with worker nodes before running distributed inference.
Export the worker node IP addresses, then replace the example values with the IPs for your own nodes:
export worker_ips="172.31.110.11:50052,172.31.110.12:50052"
You can find the IP addresses of your AWS instances in the AWS console.
Verify communication with a worker node by running the following command on the master node:
telnet 172.31.110.11 50052
If the backend server is set up correctly, the output should look like:
Trying 172.31.110.11...
Connected to 172.31.110.11.
Escape character is '^]'.
Run distributed inference using llama-cli:
bin/llama-cli -m ../../model.gguf -p "Here's a knock knock joke for kids:" -n 128 --rpc "$worker_ips" -ngl 999
It will take a significant amount of time (~10 minutes) for inference to run.
-n: maximum number of output tokens--rpc: list of backend workers-ngl: number of layers to offload to backend workers (999 offloads all layers)
build: 6209 (fb22dd07) with cc (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0 for aarch64-linux-gnu
main: llama backend init
main: load the model and apply lora adapter, if any
llama_model_load_from_file_impl: using device RPC[172.31.27.42:50052] (RPC[172.31.27.42:50052]) - 31491 MiB free
llama_model_load_from_file_impl: using device RPC[172.31.20.38:50052] (RPC[172.31.20.38:50052]) - 31491 MiB free
llama_model_loader: loaded meta data with 30 key-value pairs and 724 tensors from model.gguf (version GGUF V3 (latest))
llama_model_loader: Dumping metadata keys/values. Note: KV overrides do not apply in this output.
llama_model_loader: - kv 0: general.architecture str = llama
llama_model_loader: - kv 1: general.type str = model
llama_model_loader: - kv 2: general.name str = Llama Hf
llama_model_loader: - kv 3: general.size_label str = 71B
llama_model_loader: - kv 4: general.license str = llama3.1
llama_model_loader: - kv 5: general.tags arr[str,6] = ["facebook", "meta", "pytorch", "llam...
llama_model_loader: - kv 6: general.languages arr[str,8] = ["en", "de", "fr", "it", "pt", "hi", ...
llama_model_loader: - kv 7: llama.block_count u32 = 80
llama_model_loader: - kv 8: llama.context_length u32 = 131072
llama_model_loader: - kv 9: llama.embedding_length u32 = 8192
llama_model_loader: - kv 10: llama.feed_forward_length u32 = 28672
llama_model_loader: - kv 11: llama.attention.head_count u32 = 64
llama_model_loader: - kv 12: llama.attention.head_count_kv u32 = 8
llama_model_loader: - kv 13: llama.rope.freq_base f32 = 500000.000000
llama_model_loader: - kv 14: llama.attention.layer_norm_rms_epsilon f32 = 0.000010
llama_model_loader: - kv 15: llama.attention.key_length u32 = 128
llama_model_loader: - kv 16: llama.attention.value_length u32 = 128
llama_model_loader: - kv 17: llama.vocab_size u32 = 128256
llama_model_loader: - kv 18: llama.rope.dimension_count u32 = 128
llama_model_loader: - kv 19: tokenizer.ggml.model str = gpt2
llama_model_loader: - kv 20: tokenizer.ggml.pre str = llama-bpe
llama_model_loader: - kv 21: tokenizer.ggml.tokens arr[str,128256] = ["!", "\"", "#", "$", "%", "&", "'", ...
llama_model_loader: - kv 22: tokenizer.ggml.token_type arr[i32,128256] = [1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, ...
llama_model_loader: - kv 23: tokenizer.ggml.merges arr[str,280147] = ["Ġ Ġ", "Ġ ĠĠĠ", "ĠĠ ĠĠ", "...
llama_model_loader: - kv 24: tokenizer.ggml.bos_token_id u32 = 128000
llama_model_loader: - kv 25: tokenizer.ggml.eos_token_id u32 = 128001
llama_model_loader: - kv 26: tokenizer.ggml.add_bos_token bool = true
llama_model_loader: - kv 27: tokenizer.ggml.add_sep_token bool = false
llama_model_loader: - kv 28: general.quantization_version u32 = 2
llama_model_loader: - kv 29: general.file_type u32 = 2
llama_model_loader: - type f32: 162 tensors
llama_model_loader: - type q4_0: 561 tensors
llama_model_loader: - type q6_K: 1 tensors
print_info: file format = GGUF V3 (latest)
print_info: file type = Q4_0
print_info: file size = 37.22 GiB (4.53 BPW)
load: printing all EOG tokens:
load: - 128001 ('<|end_of_text|>')
load: - 128008 ('<|eom_id|>')
load: - 128009 ('<|eot_id|>')
load: special tokens cache size = 256
load: token to piece cache size = 0.7999 MB
print_info: arch = llama
print_info: vocab_only = 0
print_info: n_ctx_train = 131072
print_info: n_embd = 8192
print_info: n_layer = 80
print_info: n_head = 64
print_info: n_head_kv = 8
print_info: n_rot = 128
print_info: n_swa = 0
print_info: is_swa_any = 0
print_info: n_embd_head_k = 128
print_info: n_embd_head_v = 128
print_info: n_gqa = 8
print_info: n_embd_k_gqa = 1024
print_info: n_embd_v_gqa = 1024
print_info: f_norm_eps = 0.0e+00
print_info: f_norm_rms_eps = 1.0e-05
print_info: f_clamp_kqv = 0.0e+00
print_info: f_max_alibi_bias = 0.0e+00
print_info: f_logit_scale = 0.0e+00
print_info: f_attn_scale = 0.0e+00
print_info: n_ff = 28672
print_info: n_expert = 0
print_info: n_expert_used = 0
print_info: causal attn = 1
print_info: pooling type = 0
print_info: rope type = 0
print_info: rope scaling = linear
print_info: freq_base_train = 500000.0
print_info: freq_scale_train = 1
print_info: n_ctx_orig_yarn = 131072
print_info: rope_finetuned = unknown
print_info: model type = 70B
print_info: model params = 70.55 B
print_info: general.name = Llama Hf
print_info: vocab type = BPE
print_info: n_vocab = 128256
print_info: n_merges = 280147
print_info: BOS token = 128000 '<|begin_of_text|>'
print_info: EOS token = 128001 '<|end_of_text|>'
print_info: EOT token = 128009 '<|eot_id|>'
print_info: EOM token = 128008 '<|eom_id|>'
print_info: LF token = 198 'Ċ'
print_info: EOG token = 128001 '<|end_of_text|>'
print_info: EOG token = 128008 '<|eom_id|>'
print_info: EOG token = 128009 '<|eot_id|>'
print_info: max token length = 256
load_tensors: loading model tensors, this can take a while... (mmap = true)
load_tensors: offloading 80 repeating layers to GPU
load_tensors: offloading output layer to GPU
load_tensors: offloaded 81/81 layers to GPU
load_tensors: RPC[172.31.27.42:50052] model buffer size = 18821.56 MiB
load_tensors: RPC[172.31.20.38:50052] model buffer size = 18725.42 MiB
load_tensors: CPU_Mapped model buffer size = 563.62 MiB
llama_context: constructing llama_context
llama_context: n_seq_max = 1
llama_context: n_ctx = 4096
llama_context: n_ctx_per_seq = 4096
llama_context: n_batch = 2048
llama_context: n_ubatch = 512
llama_context: causal_attn = 1
llama_context: flash_attn = 0
llama_context: kv_unified = false
llama_context: freq_base = 500000.0
llama_context: freq_scale = 1
llama_context: n_ctx_per_seq (4096) < n_ctx_train (131072) -- the full capacity of the model will not be utilized
llama_context: CPU output buffer size = 0.49 MiB
llama_kv_cache_unified: RPC[172.31.27.42:50052] KV buffer size = 656.00 MiB
llama_kv_cache_unified: RPC[172.31.20.38:50052] KV buffer size = 624.00 MiB
llama_kv_cache_unified: size = 1280.00 MiB ( 4096 cells, 80 layers, 1/1 seqs), K (f16): 640.00 MiB, V (f16): 640.00 MiB
llama_context: RPC[172.31.27.42:50052] compute buffer size = 588.01 MiB
llama_context: RPC[172.31.20.38:50052] compute buffer size = 588.01 MiB
llama_context: CPU compute buffer size = 28.01 MiB
llama_context: graph nodes = 2806
llama_context: graph splits = 3
common_init_from_params: added <|end_of_text|> logit bias = -inf
common_init_from_params: added <|eom_id|> logit bias = -inf
common_init_from_params: added <|eot_id|> logit bias = -inf
common_init_from_params: setting dry_penalty_last_n to ctx_size = 4096
common_init_from_params: warming up the model with an empty run - please wait ... (--no-warmup to disable)
main: llama threadpool init, n_threads = 16
system_info: n_threads = 16 (n_threads_batch = 16) / 16 | CPU : NEON = 1 | ARM_FMA = 1 | FP16_VA = 1 | MATMUL_INT8 = 1 | SVE = 1 | DOTPROD = 1 | SVE_CNT = 16 | OPENMP = 1 | REPACK = 1 |
sampler seed: 3485539003
sampler params:
repeat_last_n = 64, repeat_penalty = 1.000, frequency_penalty = 0.000, presence_penalty = 0.000
dry_multiplier = 0.000, dry_base = 1.750, dry_allowed_length = 2, dry_penalty_last_n = 4096
top_k = 40, top_p = 0.950, min_p = 0.050, xtc_probability = 0.000, xtc_threshold = 0.100, typical_p = 1.000, top_n_sigma = -1.000, temp = 0.800
mirostat = 0, mirostat_lr = 0.100, mirostat_ent = 5.000
sampler chain: logits -> logit-bias -> penalties -> dry -> top-n-sigma -> top-k -> typical -> top-p -> min-p -> xtc -> temp-ext -> dist
generate: n_ctx = 4096, n_batch = 2048, n_predict = 64, n_keep = 1
Here's a knock knock joke for kids: Knock, knock. Who's there? The interrupting cow. The interrupting cow wh- Mooooooo!
A: He had a little lamb.
Q: What do you get if you cross an elephant and a rhinoceros?
Q: What's the difference between a cat and a comma?
A:
llama_perf_sampler_print: sampling time = 5.42 ms / 74 runs ( 0.07 ms per token, 13643.07 tokens per second)
llama_perf_context_print: load time = 489542.78 ms
llama_perf_context_print: prompt eval time = 1854.82 ms / 10 tokens ( 185.48 ms per token, 5.39 tokens per second)
llama_perf_context_print: eval time = 36101.93 ms / 63 runs ( 573.05 ms per token, 1.75 tokens per second)
llama_perf_context_print: total time = 37989.35 ms / 73 tokens
llama_perf_context_print: graphs reused = 60
That’s it! You have successfully run the llama-3.1-70B model on CPUs with the power of llama.cpp RPC functionality.
The following table provides brief description of the metrics from llama_perf:
| Log line | Description |
| sampling time | Time spent choosing next tokens using the sampling strategy (for example, top-k, top-p) |
| load time | Time required to load the model into memory and initialize weights and buffers |
| prompt eval time | Time to process the input prompt tokens before generation (fills KV cache) |
| eval time | Time to generate output tokens by forward-passing through the model |
| total time | Total time for both prompt processing and token generation (excludes model load) |
