This example runs on three AWS Graviton4 c8g.4xlarge instances. Each instance has 16 cores, 32 GB of RAM, and 200 GB of disk storage to store the downloaded and quantized model weights.
In this Learning Path, you will:
llama.cpp, a C++ library for efficient CPU inference of Llama and similar large language models on CPUs, optimized for local and embedded environments.safetensors files to a single GGUF file.The Reading time shown on the Introduction page does not include downloading, converting, and quantizing the model. These steps can take several hours depending on bandwidth and system resources. If you already have a quantized GGUF file, you can skip the download and quantization.
Before you start, make sure you have permission to access Meta’s Llama 3.1 70B parameter model .
You must repeat the install steps on each device. However, only run the download and quantization steps once as llama.cpp caches the tensors for reuse across devices.
apt update
apt install -y python3.12-venv
python3.12 -m venv myenv
source myenv/bin/activate
git clone https://github.com/ggerganov/llama.cpp
apt install -y cmake build-essential
apt install -y g++
apt install -y libcurl4-openssl-dev
cd llama.cpp
mkdir -p build-rpc
cd build-rpc
cmake .. -DGGML_RPC=ON -DLLAMA_BUILD_SERVER=ON
cmake --build . --config Release
The build output is placed in the build-rpc/bin directory.
Verify that the build succeeded by running the help command:
bin/llama-cli -h
Install Hugging Face Hub in your virtual environment:
pip3 install huggingface_hub
Create a new Python file named download.py:
cd ../..
vi download.py
Add the following code:
import os
from huggingface_hub import snapshot_download
model_id = "meta-llama/Llama-3.1-70B"
local_dir = "llama-hf"
# Create the directory if it doesn't exist
os.makedirs(local_dir, exist_ok=True)
# Download the model snapshot
snapshot_download( repo_id=model_id, local_dir=local_dir,
revision="main",
token="your_hf_token",
allow_patterns=["*.md", "*.json", "*.safetensors"]
Run the script:
python3 download.py
Install the conversion dependencies:
pip3 install -r llama.cpp/requirements.txt
Convert the model:
python3 llama.cpp/convert_hf_to_gguf.py llama-hf
Quantize the model to 4-bit weights:
cd llama.cpp/build-rpc
bin/llama-quantize ../../llama-hf/Llama-3.1-70B-F16.gguf Q4_0
You can rename the output file to model.gguf for easier use.
Check available quantization options:
bin/llama-quantize -h
This command lists supported quantization formats and options. For example:
usage: bin/llama-quantize [--help] [--allow-requantize] [--leave-output-tensor] [--pure] [--imatrix] [--include-weights] [--exclude-weights] [--output-tensor-type]
[--token-embedding-type] [--tensor-type] [--keep-split] [--override-kv] model-f32.gguf [model-quant.gguf] type [nthreads]
--allow-requantize: Allows requantizing tensors that have already been quantized. Warning: This can severely reduce quality compared to quantizing from 16bit or 32bit
--leave-output-tensor: Will leave output.weight un(re)quantized. Increases model size but may also increase quality, especially when requantizing
--pure: Disable k-quant mixtures and quantize all tensors to the same type
--imatrix file_name: use data in file_name as importance matrix for quant optimizations
--include-weights tensor_name: use importance matrix for this/these tensor(s)
--exclude-weights tensor_name: use importance matrix for this/these tensor(s)
--output-tensor-type ggml_type: use this ggml_type for the output.weight tensor
--token-embedding-type ggml_type: use this ggml_type for the token embeddings tensor
--tensor-type TENSOR=TYPE: quantize this tensor to this ggml_type. example: --tensor-type attn_q=q8_0
Advanced option to selectively quantize tensors. May be specified multiple times.
--keep-split: will generate quantized model in the same shards as input
--override-kv KEY=TYPE:VALUE
Advanced option to override model metadata by key in the quantized model. May be specified multiple times.
Note: --include-weights and --exclude-weights cannot be used together
Allowed quantization types:
2 or Q4_0 : 4.34G, +0.4685 ppl @ Llama-3-8B
3 or Q4_1 : 4.78G, +0.4511 ppl @ Llama-3-8B
8 or Q5_0 : 5.21G, +0.1316 ppl @ Llama-3-8B
9 or Q5_1 : 5.65G, +0.1062 ppl @ Llama-3-8B
19 or IQ2_XXS : 2.06 bpw quantization
20 or IQ2_XS : 2.31 bpw quantization
28 or IQ2_S : 2.5 bpw quantization
29 or IQ2_M : 2.7 bpw quantization
24 or IQ1_S : 1.56 bpw quantization
31 or IQ1_M : 1.75 bpw quantization
36 or TQ1_0 : 1.69 bpw ternarization
37 or TQ2_0 : 2.06 bpw ternarization
10 or Q2_K : 2.96G, +3.5199 ppl @ Llama-3-8B
21 or Q2_K_S : 2.96G, +3.1836 ppl @ Llama-3-8B
23 or IQ3_XXS : 3.06 bpw quantization
26 or IQ3_S : 3.44 bpw quantization
27 or IQ3_M : 3.66 bpw quantization mix
12 or Q3_K : alias for Q3_K_M
22 or IQ3_XS : 3.3 bpw quantization
11 or Q3_K_S : 3.41G, +1.6321 ppl @ Llama-3-8B
12 or Q3_K_M : 3.74G, +0.6569 ppl @ Llama-3-8B
13 or Q3_K_L : 4.03G, +0.5562 ppl @ Llama-3-8B
25 or IQ4_NL : 4.50 bpw non-linear quantization
30 or IQ4_XS : 4.25 bpw non-linear quantization
15 or Q4_K : alias for Q4_K_M
14 or Q4_K_S : 4.37G, +0.2689 ppl @ Llama-3-8B
15 or Q4_K_M : 4.58G, +0.1754 ppl @ Llama-3-8B
17 or Q5_K : alias for Q5_K_M
16 or Q5_K_S : 5.21G, +0.1049 ppl @ Llama-3-8B
17 or Q5_K_M : 5.33G, +0.0569 ppl @ Llama-3-8B
18 or Q6_K : 6.14G, +0.0217 ppl @ Llama-3-8B
7 or Q8_0 : 7.96G, +0.0026 ppl @ Llama-3-8B
1 or F16 : 14.00G, +0.0020 ppl @ Mistral-7B
32 or BF16 : 14.00G, -0.0050 ppl @ Mistral-7B
0 or F32 : 26.00G @ 7B
COPY : only copy tensors, no quantizing
