The basic attributes of a given workload are the following:
While latency is also an important factor, this section focuses on these high-level metrics to establish a foundational understanding.
Connect to an Arm-based server or cloud instance.
As an example workload, use the media manipulation tool, FFMPEG on an AWS t4g.medium instance.
This is an Arm-based (AWS Graviton2) virtual machine with two vCPUs and 4 GiB of memory, designed for general-purpose workloads with a balance of compute, memory, and network resources.
First, install the required tools:
sudo apt update
sudo apt install ffmpeg iotop -y
Download the sample video BigBuckBunny.mp4, available under the
Creative Commons Attribution 3.0 License
cd ~
mkdir src && cd src
wget http://commondatastorage.googleapis.com/gtv-videos-bucket/sample/BigBuckBunny.mp4
Run the following command to begin transcoding the video and audio using the H.264 and aac transcoders respectively. The -flush_packets flag forces FFMPEG to write each chunk of video data from memory to storage immediately, rather than buffering it in memory.
This reduces the risk of data loss in case of a crash and allows disk write activity to be more observable during monitoring, making it easier to study write behavior in real-time.
ffmpeg -i BigBuckBunny.mp4 -c:v libx264 -preset fast -crf 23 -c:a aac -b:a 128k -flush_packets 1 output_video.mp4
While the transcoding is running, you can use the pidstat command to see the disk statistics of that specific process.
pidstat -d -p $(pgrep ffmpeg) 1
Since this example video (151 MB) fits within memory, you observe no kB_rd/s for the storage device after the initial read. However, because you are flushing to storage, you observe periodic writes of approximately 275 kB_wr/s.
Linux 6.8.0-1024-aws (ip-10-248-213-118) 04/15/25 _aarch64_ (2 CPU)
10:01:24 UID PID kB_rd/s kB_wr/s kB_ccwr/s iodelay Command
10:01:25 1000 24250 0.00 276.00 0.00 0 ffmpeg
10:01:26 1000 24250 0.00 256.00 0.00 0 ffmpeg
10:01:27 1000 24250 0.00 216.00 0.00 0 ffmpeg
10:01:28 1000 24250 0.00 184.00 0.00 0 ffmpeg
10:01:29 1000 24250 0.00 424.00 0.00 0 ffmpeg
10:01:30 1000 24250 0.00 312.00 0.00 0 ffmpeg
10:01:31 1000 24250 0.00 372.00 0.00 0 ffmpeg
10:01:32 1000 24250 0.00 344.00 0.00 0 ffmpeg
In this simple example, since you are interacting with a file on the mounted filesystem, you are also observing the behavior of the filesystem.
There might be other processes or background services that are writing to this disk. You can use the iotop command for inspection. As shown in the output below, the ffmpeg process has the highest disk utilization.
sudo iotop
Total DISK READ: 0.00 B/s | Total DISK WRITE: 332.11 K/s
Current DISK READ: 0.00 B/s | Current DISK WRITE: 0.00 B/s
TID PRIO USER DISK READ DISK WRITE> COMMAND
24891 be/4 ubuntu 0.00 B/s 332.11 K/s ffmpeg -i BigBuckBunny.mp4 -c:v ~ts 1 output_video.mp4 [mux0:mp4]
1 be/4 root 0.00 B/s 0.00 B/s systemd --system --deserialize=74
2 be/4 root 0.00 B/s 0.00 B/s [kthreadd]
Using the input/output statistics command (iostat), you can observe the system-wide metrics from the nvme0n1 drive.
Be mindful of the fact that you are using a snapshot of this workload; more accurate characteristics can be obtained by measuring the distribution of a workload.
watch -n 0.1 iostat -z nvme0n1
You see output similar to that below.
Device tps kB_read/s kB_wrtn/s kB_dscd/s kB_read kB_wrtn kB_dscd
nvme0n1 3.81 31.63 217.08 0.00 831846 5709210 0
To observe more detailed metrics, you can run iostat with the -x option.
iostat -xz nvme0n1
The output is similar to:
Device r/s rkB/s rrqm/s %rrqm r_await rareq-sz w/s wkB/s wrqm/s %wrqm w_await wareq-sz d/s dkB/s drqm/s %drqm d_await dareq-sz f/s f_await aqu-sz %util
nvme0n1 0.66 29.64 0.24 26.27 0.73 44.80 2.92 203.88 3.17 52.01 2.16 69.70 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.01 0.15
This is a simple transcoding workload with flushed writes, where most data is processed and stored in memory. Disk I/O is minimal, with an IOPS of just 3.81, low throughput (248.71 kB/s), and an average IO depth of 0.01 — all summarized in very low disk utilization. The 52% write merge rate and low latencies further suggest sequential, infrequent disk access, reinforcing that the workload is primarily memory-bound.
| Metric | Calculation Explanation | Value |
| IOPS | Taken directly from the tps (transfers per second) field | 3.81 |
| Throughput (Read) | From monitoring tool output | 31.63 kB/s |
| Throughput (Write) | From monitoring tool output | 217.08 kB/s |
| Throughput (Total) | Sum of read and write throughput | 248.71 kB/s |
| Avg I/O Size | Total throughput divided by IOPS: 248.71 / 3.81 | ≈ 65.3 KB |
| Read Ratio | Read throughput ÷ total throughput: 31.63 / 248.71 | ~13% |
| Write Ratio | Write throughput ÷ total throughput: 217.08 / 248.71 | ~87% |
| IO Depth | Taken directly from aqu-sz (average number of in-flight I/Os) | 0.01 |
| Access Pattern | 52% of writes were merged (wrqm/s = 3.17, w/s = 2.92), indicating mostly sequential disk access with low wait times and frequent cache hits | Sequential (52.01% merged) |
If you have access to the workload’s source code, you can more easily observe the expected access patterns.
