Explore related resources
Give feedback
AI-assisted
Close
How do I know the additional volumes are attached correctly before running `fio`?
After attaching the volumes in the cloud console, the instance should expose two new block devices. Verify that the expected device identifiers are available so you can target them in tests.
Which `fio` job parameters should I choose to reflect my workload?
Base your job on the attributes you observed from the real workload: I/O size, read/write ratio, sequential versus random access, target IOPS, and throughput. Keep the profile consistent when comparing devices.
What should I look for in `fio` output to compare devices?
Focus on reported IOPS and throughput for the selected job profile. Compare those values across runs to see how each block device behaves under the same conditions.
When should I run `iostat`, `iotop`, and `pidstat` during this process?
Run them while the workload and fio jobs are active to observe device utilization and per-process activity. Use these observations to spot contention and guide the next test configuration.
Do I need to use the exact instance type shown in the example?
The example uses an Arm-based cloud instance to illustrate the workflow. You can follow the same steps on an Arm Linux server or another Arm-based instance.
