# Train and benchmark DeepSpeed on an Arm Axion VM
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/servers-and-cloud-computing/deepspeed-on-axion/)
- [Understand DeepSpeed and Google Axion C4A for AI training](https://learn.arm.com/learning-paths/servers-and-cloud-computing/deepspeed-on-axion/background/)
- [Create a Google Axion C4A virtual machine for DeepSpeed](https://learn.arm.com/learning-paths/servers-and-cloud-computing/deepspeed-on-axion/instance/)
- [Set up PyTorch and DeepSpeed on a Google Axion C4A virtual machine](https://learn.arm.com/learning-paths/servers-and-cloud-computing/deepspeed-on-axion/install-deepspeed-arm/)
- [Train and benchmark DeepSpeed on an Arm Axion VM](https://learn.arm.com/learning-paths/servers-and-cloud-computing/deepspeed-on-axion/train-benchmark-deepspeed-arm/)
- [Next Steps](https://learn.arm.com/learning-paths/servers-and-cloud-computing/deepspeed-on-axion/_next-steps/)
## Prepare training and benchmarking AI workloads
In this section, you’ll run neural network training and benchmarking workloads on an Arm-based Google Axion C4A VM using PyTorch. You’ll run two workloads: a small baseline model to verify the environment, and a larger benchmark to evaluate CPU scaling behavior.
If you’re continuing in the same SSH session from the previous section, the `deepspeed-env` virtual environment is already active and your working directory is `~/deepspeed-demo`. If you’ve opened a new session, re-activate the environment and navigate to the project directory:
source ~/deepspeed-env/bin/activate
cd ~/deepspeed-demo
## Set up a baseline
First, create and run a baseline model to verify the environment.
### Create a baseline training workload
Create a lightweight neural network training script to verify the environment. The script defines a three-layer feedforward network and generates synthetic training data. It runs five epochs of mini-batch gradient descent using the Adam optimizer, and prints the total training time:
cat > train.py << 'EOF'
import torch
import torch.nn as nn
import torch.optim as optim
import time
class SimpleModel(nn.Module):
    def __init__(self):
        super().__init__()
        self.net = nn.Sequential(
            nn.Linear(128, 256),
            nn.ReLU(),
            nn.Linear(256, 64),
            nn.ReLU(),
            nn.Linear(64, 1)
    def forward(self, x):
        return self.net(x)
model = SimpleModel()
optimizer = optim.Adam(model.parameters(), lr=0.001)
data = torch.randn(5000, 128)
target = torch.randn(5000, 1)
start = time.time()
for epoch in range(5):
    total_loss = 0
    for i in range(0, len(data), 32):
        x = data[i:i+32]
        y = target[i:i+32]
        output = model(x)
        loss = ((output - y) ** 2).mean()
        optimizer.zero_grad()
        loss.backward()
        optimizer.step()
        total_loss += loss.item()
    print(f"Epoch {epoch+1}, Loss: {total_loss}")
end = time.time()
print("Total Training Time:", end - start)
EOF
### Run the baseline training workload
Run the training script:
python train.py
The output is similar to:
__output__Epoch 1, Loss: 155.41862654685974
__output__Epoch 2, Loss: 146.19861325621605
__output__Epoch 3, Loss: 130.47488084435463
__output__Epoch 4, Loss: 100.75305489450693
__output__Epoch 5, Loss: 65.7514722738415
__output__Total Training Time: 0.7545099258422852
The loss decreases across all five epochs, confirming that gradient updates are working correctly and PyTorch is running properly on Arm64.
### Run the baseline with timing
Run the same script under `time` and save the output for comparison:
time python train.py | tee pytorch_baseline_result.txt
__output__Epoch 1, Loss: 160.0170536339283
__output__Epoch 2, Loss: 151.6725998222828
__output__Epoch 3, Loss: 136.18832343816757
__output__Epoch 4, Loss: 108.03106728196144
__output__Epoch 5, Loss: 73.08194716647267
__output__Total Training Time: 0.7314252853393555
__output__
__output__real    0m2.172s
__output__user    0m3.700s
__output__sys     0m0.137s
The `real` time is the total wall-clock duration. The `user` time exceeds `real` time here because PyTorch uses multiple threads across all 4 vCPUs, so CPU time is summed across cores.
## Set up a large-scale benchmark
After creating and running the baseline workload, create a large-scale benchmark to evaluate CPU behavior.
### Create a large-scale benchmark
This workload increases dataset size, input dimensionality, batch size, and model depth to stress CPU compute, memory bandwidth, and tensor operation throughput. It also calls `torch.set_num_threads(os.cpu_count())` to explicitly pin PyTorch to all available cores:
cat > train_large.py << 'EOF'
import torch
import time
import os
class LargeModel(nn.Module):
    def __init__(self):
        super().__init__()
            nn.Linear(512, 1024),
            nn.ReLU(),
            nn.Linear(1024, 512),
            nn.ReLU(),
            nn.Linear(512, 128),
            nn.ReLU(),
            nn.Linear(128, 1)
        return self.net(x)
model = LargeModel()
data = torch.randn(20000, 512)
target = torch.randn(20000, 1)
start = time.time()
    total_loss = 0
    for i in range(0, len(data), 64):
        x = data[i:i+64]
        y = target[i:i+64]
        output = model(x)
        loss.backward()
        optimizer.step()
end = time.time()
EOF
To observe CPU utilization while this runs, open a second terminal and run `top`. Look for the Python process — the CPU percentage reflects multi-threaded utilization across all 4 vCPUs.
### Run the large benchmark with timing
Run the benchmark script under `time`:
time python train_large.py | tee pytorch_large_result.txt
__output__Epoch 1, Loss: 319.07712411880493
__output__Epoch 2, Loss: 308.4675619006157
__output__Epoch 3, Loss: 273.5877128839493
__output__Epoch 4, Loss: 227.81050024926662
__output__Epoch 5, Loss: 194.74351280927658
__output__Total Training Time: 4.878139972686768
__output__
__output__real    0m6.346s
__output__user    0m19.630s
__output__sys     0m0.251s
Training time scales roughly linearly with dataset size and model depth. The `user` time being approximately 4x `real` time indicates that PyTorch is distributing work across all 4 vCPUs effectively.
## Review benchmark outputs
After both scripts complete, review the timing outputs and compare the two workloads.
### Verify generated files for both workloads
Confirm that the output files are present:
ls -lh
__output__-rw-r--r-- 1 user user  12K May 15 13:50 pytorch_baseline_result.txt
__output__-rw-r--r-- 1 user user  12K May 15 13:55 pytorch_large_result.txt
__output__-rw-r--r-- 1 user user 1.1K May 15 13:48 train.py
__output__-rw-r--r-- 1 user user 1.2K May 15 13:48 train_large.py
### Compare training times
The following table describes approximate training times:
| Workload                                      | Approximate training time  |
| Baseline model (5K samples, 128 features)    | ~0.7–0.8 seconds            |
| Large benchmark (20K samples, 512 features)  | ~4.8–5.4 seconds            |
Both workloads trained to completion with steadily decreasing loss, indicating stable PyTorch CPU execution on Google Axion C4A. Your results may vary depending on VM load at the time of the run.
## What you’ve accomplished
You’ve run two PyTorch training workloads on a Google Axion Arm64 VM, measured wall-clock and CPU execution time, and confirmed stable multi-threaded neural network training on SUSE Linux.
