# Set up PyTorch and DeepSpeed on a Google Axion C4A virtual machine
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/servers-and-cloud-computing/deepspeed-on-axion/)
- [Understand DeepSpeed and Google Axion C4A for AI training](https://learn.arm.com/learning-paths/servers-and-cloud-computing/deepspeed-on-axion/background/)
- [Create a Google Axion C4A virtual machine for DeepSpeed](https://learn.arm.com/learning-paths/servers-and-cloud-computing/deepspeed-on-axion/instance/)
- [Set up PyTorch and DeepSpeed on a Google Axion C4A virtual machine](https://learn.arm.com/learning-paths/servers-and-cloud-computing/deepspeed-on-axion/install-deepspeed-arm/)
- [Train and benchmark DeepSpeed on an Arm Axion VM](https://learn.arm.com/learning-paths/servers-and-cloud-computing/deepspeed-on-axion/train-benchmark-deepspeed-arm/)
- [Next Steps](https://learn.arm.com/learning-paths/servers-and-cloud-computing/deepspeed-on-axion/_next-steps/)
## Set up the Python environment
First, install Python 3.11 and create a virtual environment on the Google Axion virtual machine (VM) running SUSE Linux.
### Verify Arm64 architecture
Verify that the VM is running on Arm64 architecture:
uname -m
The output is similar to:
aarch64
Check CPU details:
lscpu
__output__ Architecture:                aarch64
__output__   CPU op-mode(s):            64-bit
__output__   Byte Order:                Little Endian
__output__ CPU(s):                      4
__output__   On-line CPU(s) list:       0-3
__output__ Vendor ID:                   ARM
__output__   Model name:                Neoverse-V2
The `Neoverse-V2` model name confirms you’re running on a Google Axion processor. The `aarch64` architecture confirms the 64-bit Arm environment that PyTorch and DeepSpeed will target.
### Install Python
The default Python version on SUSE Linux might conflict with PyTorch and DeepSpeed dependencies. Python 3.11 provides stable support for both frameworks and avoids compatibility issues commonly seen with older or newer releases:
sudo zypper install -y python311 python311-pip python311-devel
### Create a Python virtual environment
Create an isolated Python environment to prevent dependency conflicts with system packages:
python3.11 -m venv deepspeed-env
Activate the virtual environment:
source ~/deepspeed-env/bin/activate
Verify the Python version in the environment:
python --version
__output__ Python 3.11.10
### Upgrade pip
Upgrade pip, setuptools, and wheel before installing packages. Outdated packaging tools can cause installation failures or wheel compatibility issues, particularly on Arm64:
pip install --upgrade pip setuptools wheel
### Install Ninja
Ninja is a lightweight build system used by PyTorch and DeepSpeed to compile native extensions at runtime.
To avoid SUSE repository dependency issues sometimes seen on cloud Arm64 images, install Ninja using `pip` rather than `zypper`:
pip install ninja
Verify the installation:
ninja --version
__output__ 1.13.0.git.kitware.jobserver-pipe-1
## Install PyTorch and DeepSpeed
After setting up the Python environment, install PyTorch and DeepSpeed on the VM.
### Install CPU-only PyTorch
Google Axion VMs are CPU-only systems and don’t contain NVIDIA GPUs. To avoid unnecessary CUDA dependencies and reduce package size, install the CPU-only PyTorch build:
pip install torch torchvision torchaudio --index-url https://download.pytorch.org/whl/cpu
pip install torch torchvision torchaudio --index-url [https://download.pytorch.org/whl/cpu](https://download.pytorch.org/whl/cpu)
### Verify PyTorch installation
Verify that you installed PyTorch successfully:
python -c "import torch; print(torch.__version__)"
__output__ 2.12.0+cpu
Check CUDA availability:
python -c "import torch; print(torch.cuda.is_available())"
__output__ False
This is expected because Google Axion VMs are CPU-only systems.
### Install DeepSpeed
DeepSpeed’s distributed CPU extensions require GCC 9 or later to compile. The default SUSE Linux image on Google Axion ships with GCC 7.5.0. When DeepSpeed initializes its launcher, it attempts to compile the `deepspeed_shm_comm` shared memory communication extension. This compilation fails on GCC 7.5.0.
To work around this, install DeepSpeed with all native extension compilation disabled. Each variable tells the build system to skip a specific extension that requires GCC 9 or later:
| Variable                | Purpose                                      |
| `DS_BUILD_OPS=0`       | Disables native op compilation               |
| `DS_BUILD_SHM_COMM=0`  | Disables the shared memory communication extension |
| `DS_BUILD_CPU_ADAM=0`  | Disables the CPU Adam optimizer extension    |
| `DS_BUILD_AIO=0`       | Disables async I/O extensions                 |
DS_BUILD_OPS=0 DS_BUILD_SHM_COMM=0 DS_BUILD_CPU_ADAM=0 DS_BUILD_AIO=0 pip install deepspeed
### Verify DeepSpeed installation
Verify that DeepSpeed was installed successfully:
ds_report
__output__ [WARNING] Setting accelerator to CPU. If you have GPU or other accelerator, we were unable to detect it.
__output__ --------------------------------------------------
__output__ DeepSpeed C++/CUDA extension op report
__output__ NOTE: Ops not installed will be just-in-time (JIT) compiled at
__output__       runtime if needed. Op compatibility means that your system
__output__       meet the required dependencies to JIT install the op.
__output__ JIT compiled ops requires ninja
__output__ ninja .................. [OKAY]
__output__ op name ................ installed .. compatible
__output__ deepspeed_not_implemented  [NO] ....... [OKAY]
__output__  [WARNING]  async_io requires the dev libaio .so object and headers but these were not found.
__output__  [WARNING]  async_io: please install the libaio-devel package with yum
__output__ async_io ............... [NO] ....... [NO]
__output__ deepspeed_ccl_comm ..... [NO] ....... [OKAY]
__output__ deepspeed_shm_comm ..... [NO] ....... [OKAY]
__output__ cpu_adam ............... [NO] ....... [OKAY]
__output__ fused_adam ............. [NO] ....... [OKAY]
__output__ DeepSpeed general environment info:
__output__ torch install path ............... ['/home/user/deepspeed-env/lib64/python3.11/site-packages/torch']
__output__ torch version .................... 2.12.0+cpu
__output__ deepspeed install path ........... ['/home/user/deepspeed-env/lib64/python3.11/site-packages/deepspeed']
__output__ deepspeed info ................... 0.19.0, unknown, unknown
__output__ deepspeed wheel compiled w. ...... torch 0.0
__output__ shared memory (/dev/shm) size .... 7.80 GB
The CPU accelerator warning is expected because Google Axion VMs have no GPU. Most ops show `[NO] ... [OKAY]`, meaning they are not pre-installed but are compatible for just-in-time compilation with Ninja if needed at runtime. The one exception is `async_io`, which shows `[NO] ... [NO]` because it requires the `libaio-devel` system package. Because async I/O isn’t needed for the training workloads in this Learning Path, and it was disabled with `DS_BUILD_AIO=0`, you can ignore this warning.
## Create a project directory
Create a working directory for your DeepSpeed training scripts:
mkdir ~/deepspeed-demo
cd ~/deepspeed-demo
> **Note:** Don’t run `deepspeed train.py` directly on this VM. DeepSpeed’s launcher attempts to compile the `deepspeed_shm_comm` native extension during initialization, which requires GCC 9 or later. Use `python train.py` instead, as shown in the next section.
## Troubleshoot setup issues
Use the following guidance to troubleshoot issues with setting up the Python environment for the project.
### SUSE repository refresh issue
You might see the following error during `zypper` commands:
__output__ Receive: script died unexpectedly
If Python 3.11 is already installed when this occurs, you can continue. Install all remaining packages using `pip` inside the virtual environment and avoid relying on SUSE development repositories.
## What you’ve accomplished and what’s next
You’ve now installed Python 3.11, PyTorch, and DeepSpeed on a Google Axion C4A VM running SUSE Linux, verified the environment with `ds_report`, and created the project directory for training scripts.
Next, you’ll create and run neural network training and benchmarking workloads on the VM.
