# Next Steps
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/servers-and-cloud-computing/deepspeed-on-axion/)
- [Understand DeepSpeed and Google Axion C4A for AI training](https://learn.arm.com/learning-paths/servers-and-cloud-computing/deepspeed-on-axion/background/)
- [Create a Google Axion C4A virtual machine for DeepSpeed](https://learn.arm.com/learning-paths/servers-and-cloud-computing/deepspeed-on-axion/instance/)
- [Set up PyTorch and DeepSpeed on a Google Axion C4A virtual machine](https://learn.arm.com/learning-paths/servers-and-cloud-computing/deepspeed-on-axion/install-deepspeed-arm/)
- [Train and benchmark DeepSpeed on an Arm Axion VM](https://learn.arm.com/learning-paths/servers-and-cloud-computing/deepspeed-on-axion/train-benchmark-deepspeed-arm/)
- [Next Steps](https://learn.arm.com/learning-paths/servers-and-cloud-computing/deepspeed-on-axion/_next-steps/)
## Explore related resources
- [DeepSpeed official documentation](https://www.deepspeed.ai/)
- [DeepSpeed GitHub repository](https://github.com/microsoft/DeepSpeed)
- [PyTorch documentation](https://pytorch.org/docs/stable/index.html)
- [Introducing Google Axion Processors](https://cloud.google.com/blog/products/compute/introducing-googles-new-arm-based-cpu)
- [Arm Neoverse V2 platform](https://www.arm.com/products/silicon-ip-cpu/neoverse/neoverse-v2)
## Review frequently asked questions
### How do I know the VM is Arm64 and running on Axion cores?
Run `uname -m` and confirm that the output is `aarch64`. Then run `lscpu` and check that the model name reports `Neoverse-V2`.
### Which Google Cloud VM configuration should I use for the steps?
Use the `c4a-standard-4` machine type with 4 vCPUs and 16 GB of memory. This configuration hosts the PyTorch and DeepSpeed workloads.
### Which Python version do I need and what is the virtual environment called?
Install Python 3.11 and create a virtual environment for the project. The path uses an environment named `deepspeed-env`.
### I opened a new SSH session. What should I do before running workloads?
Re-activate the `deepspeed-env` virtual environment and navigate to the `~/deepspeed-demo` directory. This ensures the correct dependencies and paths are active.
### What result should I expect from the baseline and benchmark runs?
The baseline model should run without errors and print training logs, confirming that PyTorch and DeepSpeed are correctly installed. The larger benchmark runs longer and lets you observe CPU scaling behavior by reviewing its logs and runtime characteristics.
