Explore related resources
Give feedback
AI-assisted
Close
What do I need before running the 671B model?
Use an Arm server running Ubuntu 24.04 LTS with at least 64 cores, 512 GB of RAM, and 400 GB of disk space. The Learning Path was tested on an AWS Graviton4 r8g.24xlarge instance.
Which DeepSeek-R1 model should I download?
Download a pre-quantized DeepSeek-R1 model from Hugging Face. Quantization enables efficient CPU inference with llama.cpp.
How do I know the llama.cpp server binary is available?
Running make during the build step creates the server executable. If it’s missing, repeat the build step before starting the server.
How do I access the model repeatedly without restarting it?
Start the llama.cpp server and use its OpenAI-compatible API to submit multiple requests. You can also send requests from another machine to the host running the server.
Why do I install jq?
The examples use jq to work with JSON. jq helps format and parse responses returned by the OpenAI-compatible API calls.
