In this section, you’ll learn how to use Google Benchmark and Profile-Guided Optimization to improve the performance of a simple division operation. This example demonstrates how even seemingly straightforward operations can benefit from optimization techniques.
Integer division is ideal for benchmarking because it’s significantly more expensive than operations like addition, subtraction, or multiplication. On most CPU architectures, including Arm, division instructions have higher latency and lower throughput compared to other arithmetic operations. By applying Profile-Guided Optimization to code containing division operations, we can potentially achieve significant performance improvements.
For this example, you can use any Arm Linux computer. For example, an AWS EC2 c7g.xlarge instance running Ubuntu 24.04 LTS can be used.
Run the following commands to install the prerequisite packages:
sudo apt update
sudo apt install gcc g++ make libbenchmark-dev -y
Use an editor to copy and paste the C++ source code below into a file named div_bench.cpp.
This trivial example takes in a vector of 4096 32-bit integers and divides each element by a number. Importantly, the use of benchmark/benchmark.h introduces indirection since the divisor value is unknown at compile time, although it is visible in the source code as 1500.
#include <benchmark/benchmark.h>
#include <vector>
// Benchmark division instruction
static void baseDiv(benchmark::State &s) {
std::vector<int> v_in(4096);
std::vector<int> v_out(4096);
for (auto _ : s) {
for (size_t i = 0; i < v_in.size(); i++) v_out[i] = v_in[i] / s.range(0);
// s.range(0) is unknown at compile time, cannot be reduced
BENCHMARK(baseDiv)->Arg(1500)->Unit(benchmark::kMicrosecond); // value of 1500 is passed through as an argument so strength reduction cannot be applied
BENCHMARK_MAIN();
To compile and run the microbenchmark on this function, you need to link with the pthreads and benchmark libraries.
Compile with the command:
g++ -O3 -std=c++17 div_bench.cpp -lbenchmark -lpthread -o div_bench.base
Run the program:
./div_bench.base
Running ./div_bench.base
Run on (4 X 2100 MHz CPU s)
CPU Caches:
L1 Data 64 KiB (x4)
L1 Instruction 64 KiB (x4)
L2 Unified 1024 KiB (x4)
L3 Unified 32768 KiB (x1)
Load Average: 0.00, 0.00, 0.00
***WARNING*** Library was built as DEBUG. Timings may be affected.
Benchmark Time CPU Iterations
baseDiv/1500 7.90 us 7.90 us 88512
To inspect what assembly instructions are being executed most frequently, you can use the perf command. This is useful for identifying bottlenecks and understanding the performance characteristics of your code.
Install Perf using the install guide before proceeding.
You may need to set the perf_event_paranoid value to -1 with the sudo sysctl kernel.perf_event_paranoid=-1 command to run the commands below.
Run the following commands to record perf data and create a report in the terminal:
sudo perf record -o perf-division-base ./div_bench.base
sudo perf report --input=perf-division-base
As the perf report graphic below shows, the program spends a significant amount of time in the short loops with no loop unrolling. There is also an expensive sdiv operation, and most of the execution time is spent storing the result of the operation.
