Optimize C++ with PGO and Google Benchmark
Build the instrumented binary with
-fprofile-generate, run it to collect runtime data, then rebuild with -fprofile-use. This two-step cycle enables the compiler to use the collected profile during optimization.The run generates profile data files with a
.gcda extension in the same directory. Use these files as inputs for the subsequent -fprofile-use build.Google Benchmark runs managed iterations and reports timing results for the benchmarked function. You should see timing output you can compare across the non-PGO and PGO builds.
Verify that you ran the instrumented binary and that
.gcda files exist in the build directory. Then confirm that the recompile used -fprofile-use in the same location where the the run generated the profile files.Use PGO for performance-critical code that runtime behavior strongly influences. Avoid applying it broadly to early-stage code or highly variable workloads because the extra build steps add time and may not yield stable benefits.
