You should see the Couchbase Web Console for initial setup or login. After completing the setup, the Servers page should show your node as healthy and your test bucket should appear in the Buckets view.
Create a GCP firewall rule that allows TCP port
8091 and applies to your instance. Confirm that the VM is running, note its external IP, and try again.The steps use zypper for SUSE-based systems. Follow the commands as shown to refresh repositories, update the system, and install required tools before adding Couchbase.
Confirm that the web console responds on port
8091, cluster initialization is complete, the node shows healthy status, and a test bucket exists. These checks indicate that the deployment is ready for workload testing.Run YCSB after you verify console access, complete cluster setup, and create a bucket. The specific YCSB commands aren’t listed here, so use your verified bucket name and credentials when you proceed.
