In the first GitHub Copilot Extension Learning Path, you created a Flask app in the section titled “ How can I create my own private GitHub Copilot Extension? ”.
You will now deploy this Flask app on your newly created EC2 instance. First, retrieve your EC2 instance ID:
aws ec2 describe-instances --filters "Name=tag:Name,Values=CopilotExtensionDeploymentStack/LaunchTemplate" --query "Reservations[*].Instances[*].InstanceId" --output text
Next, use this ID to log in with AWS SSM. Because your instance is in a private subnet for security purposes, you must use SSM.
The SSM agent running on the instance creates a secure tunnel that lets you SSH in with the following command:
aws ssm start-session --target [your instance ID]
You can now follow the steps in “ How can I create my own private GitHub Copilot Extension? ” to create your Flask app, set up a Python virtual environment, and install the necessary packages.
The only two changes that you need to make are:
0.0.0.0 port 8080, which the ALB is configured to listen on.First, add the following endpoint to your main Flask file:
@app.route('/health')
def health():
return Response(status=200)
Next, add the host argument to the app.run call at the end of the file and update the port number.
The final result should look like this:
if __name__ == '__main__':
app.run(host='0.0.0.0', port=8080)
This exposes your app to the port that the ALB listener is monitoring.
Run the simple extension:
python ./simple-extension.py
Now, if you navigate to your API subdomain in a browser, you should see:
"Hello! Welcome to the example GitHub Copilot Extension in Python!"
Your API is now complete and ready to be configured in your GitHub Application.
